Old 04-24-2007, 08:06 PM   #1
1/2" or 5/8"?
Quick question. I bought a new bathroom faucet and the piping. I checked all the bins for the shutoff valves, and i could not find one with 1/2" OD inlet, 3/8" outlet for copper pipe compression fitting. The ones I ended up buying are 5/8" OD inlet, 3/8" outlet. I did see the 1/2" inlet in iron pipe thread-type, and for sweat fitting. Am I correct in assuming that there is no 1/2" OD inlet for compression fitting, and are the valves I bought going to work with my plumbing. Plumbing is standard midwest under-sink plumbing. Thanks.
Mr. Michael is offline   Reply With Quote
Old 04-24-2007, 09:23 PM   #2
1/2" or 5/8"?
As long as your sink is fed with 1/2" type L (or sometimes even type M) copper tubing, you have the right shutoff valves. The 1/2" designation is inside diameter - outside diameter is 5/8".
Ishmael is offline   Reply With Quote
Old 04-25-2007, 09:06 PM   #3
1/2" or 5/8"?
that's what I was thinking, ID vs. OD. Just wanted to double check with someone before I cut the pipe. Thanks.
Laying 5/8" Bamboo Flooring kirkeric Flooring 7 08-13-2007 03:36 PM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 04:15 AM
1/2" breakers Clutchcargo Electrical 3 06-22-2007 07:28 AM
properly nailing down 1/2" osb sheeting over lath FISH275 Roofing 2 04-08-2007 01:49 PM
