-   -   1/2" or 5/8"? (http://www.diychatroom.com/f7/1-2-5-8-a-7995/)
Mr. Michael 04-24-2007 07:06 PM
1/2" or 5/8"?
Quick question. I bought a new bathroom faucet and the piping. I checked all the bins for the shutoff valves, and i could not find one with 1/2" OD inlet, 3/8" outlet for copper pipe compression fitting. The ones I ended up buying are 5/8" OD inlet, 3/8" outlet. I did see the 1/2" inlet in iron pipe thread-type, and for sweat fitting. Am I correct in assuming that there is no 1/2" OD inlet for compression fitting, and are the valves I bought going to work with my plumbing. Plumbing is standard midwest under-sink plumbing. Thanks.
Ishmael 04-24-2007 08:23 PM
As long as your sink is fed with 1/2" type L (or sometimes even type M) copper tubing, you have the right shutoff valves. The 1/2" designation is inside diameter - outside diameter is 5/8".
Mr. Michael 04-25-2007 08:06 PM
that's what I was thinking, ID vs. OD. Just wanted to double check with someone before I cut the pipe. Thanks.:thumbsup:
