1/2 -> 1/4 Valve Leaks - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2013, 05:13 PM   #31
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Oh the plyers was from my previous attempts at getting it to work. I thought I had to keep going till I no longer see thread. This time I only hand tightened it and then used pliers to go a quarter or so turn.
I tried to find the shark bite but it had a threaded end (like a water heater would have, not a hose) and I could not find the other part that would be needed to go from the 1/2 pex.
I'll monitor this for now and see how it goes. I was even brave enough to turn the valve all the way, normally I could only get away with opening it a slight touch. If it still leaks after this I'll have to go to another hardware store and see if they have something else I can try.
Old 01-05-2013, 05:31 PM   #32
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
Actually, it doesn't matter if the valve is open 10% or 100%. If there is no flow, the pressure will still be the same.
Old 01-05-2013, 07:32 PM   #33
Rewards Points: 1,668
With that connection I wouldn't leave the house with the valve turned on more than a trickle.
Old 01-05-2013, 07:37 PM   #34
Wire Chewer
Rewards Points: 132
So it's not good then? Do I need to make it tighter?
So what *IS* the proper way to go from 1/2 to 1/4? I found barely nothing at the hardware store. The closest thing was that shark bite but I could not find a threaded end to go with it as it was a 1/2 thread and 1/4 shark bite. Seems this should be something trivial.
Old 01-06-2013, 07:09 AM   #35
Rewards Points: 1,216
Just an opinion, I don't think Utilities Companies would operate their water pressure mains at that hi of pressure because it would cause wear and tear on their equipment and the system throughout the town. I would start by buying a gage that attachés to the hose connection on your house and go from there.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 01-06-2013, 10:38 AM   #36
JOATMON
ddawg16's Avatar
The water pressure in most areas is purely a function of the height of the water tower. You get about 5 PSI of water pressure for every 10' of height. If you have a 50' water tower, then your going to have 'around' 25 PSI at the base. Then, depending on your elevation relative to the tower, it will most likely be higher. You will get minor changes in pressure do to flow losses....but if nothing is flowing, the pressure will be at it's max.
Personally, I've never seen anything over about 95 PSI.
Old 01-06-2013, 10:44 AM   #37
We don't have towers that provide city water, pumps are used. However we do have water towers in some places for emergency fire water.
Old 01-06-2013, 11:25 AM   #38
Wire Chewer
Rewards Points: 132
Ours is around 127ft according to this site:
http://www.eureka4you.com/wtower-on-t/Timmins.htm
Found that at random, not sure how accurate it really is.
I have not been able to find a gauge to test though but did find this on ebay: http://www.ebay.com/itm/Industrial-W...item2a1774a154
Is that a connector that can be converted to 1/2 inch copper or pex in any way? Never heard of that type of connector before. There was one at home depot that only went to 100psi and I think it may of had that same connector but it was labelled as being for water pump applications.
Old 01-06-2013, 11:35 AM   #39
Home Depot has one that just hooks up to the outside spigot that will give you the pressure. I think it goes up to 100 lbs. Not totally sure of the 100 LBS.
I think I seen them near the water heaters, memory not what it used to be.
Main Water Shutoff Valve problem obadran Plumbing 16 12-10-2012 11:45 AM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Shut off valve for outdoor spigot C4per Plumbing 15 11-24-2012 07:50 AM
Boiler pressure valve leaks water on shutdown erockaway HVAC 16 10-15-2012 10:11 PM
