1 1/4" PO Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2008, 04:16 PM   #1
1 1/4" PO drain
I recently puchased a copper undermount sink. When the plumber went to install the drain we discovered that the threads for the drain did not go up the pipe far enough. Apparently the lip of the sink is very thin. To compound the situation the drain is 1 1/4" oil rubbed bronze....not to easy to find. Any suggestions on a drain that is threaded all the way up? Quit Laughing....plumbing is not my strong point.
Haveninc is offline   Reply With Quote
Old 03-16-2008, 05:42 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I'm assuming you're trying to attach a pop-up assembly for a lav to what's actually more or less designed to be a bar sink ?
Journeyman Plumber
Old 03-16-2008, 07:29 PM   #3
Yes it is for a bar sink. The copper is so thin that there is not enough thread on the drain line to attach it. When you try to order one online it doesn't tell you whether there is more thread than normal. We've already been through 3 drains.
Old 03-18-2008, 02:51 AM   #4
I blame ProWallGuy
Rewards Points: 150
You need an old fashioned drain with a stopper.
The one in the top left, center, the P0002S might work, if its available in the proper finish. According to the 2007 price list, its not. The brand is "Sign of the Crab", google it and call them. You can ask them about dimensions on it and any finishes that might be special order.
Failing that, contact the sink manufacturer and see what they recommend.
Double A is offline   Reply With Quote
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Drain location off by 1/4" jross Plumbing 24 03-30-2007 06:39 PM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 03:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
