1 And 1/2" Trap Adapter For 2" Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2009, 04:35 PM   #1
00000000000000000
00000000000000000000000000000
maxfischersweet is offline   Reply With Quote
Old 11-18-2009, 10:01 PM   #2
can you use a 2" x 1 1/2" coupling with a trap adaptor that goes inside the 1 1/2" fitting? will that give you enough room?
plumber Jim is offline   Reply With Quote
Old 11-19-2009, 09:56 AM   #3
0000000000000000000000000000000000000000000000
Old 11-19-2009, 01:10 PM   #4
Rewards Points: 3,130
Originally Posted by maxfischersweet View Post
so what should i do, and why dont they make a 1 and 1/2" trap adapter that fits inside of a 2" pipe. if they do let me know where i can get it, if they dont, thats seems pretty stupid.
thanks
Unless I'm misunderstanding, what you're looking for is a common plumbing part available most anywhere. I bought one at Home Depot (or maybe it was Lowe's) just the other day.
Old 11-19-2009, 04:10 PM   #5
Old 11-19-2009, 11:33 PM   #6
I have never seen a trap adaptor that will go into 2" all the fittings will go on the pipe not in it. what you can do is cut the 2" pipe down below the floor level with a inside cutter or a dremel so that when you glue on the 2" x 1 1/2" coupling it will be flush with the floor, Then glue the trap adaptor that is designed to go inside the 1 1/2" fitting.
tub drain off by 1/2", worth busting concrete? thezs Plumbing 12 12-30-2012 01:04 PM
1/2" pipe fittings don't fit old pipe- PLEASE HELP carjack Plumbing 1 05-21-2009 04:22 AM
help re-installing shower head 1/2" pipe extension cbons Plumbing 2 04-15-2009 06:06 PM
1/2" soft copper pipe is stuck JT61 Plumbing 5 02-11-2009 03:30 PM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 04:15 AM
