-   -   1 and 1/2" trap adapter for 2" drain pipe (http://www.diychatroom.com/f7/1-1-2-trap-adapter-2-drain-pipe-57489/)
maxfischersweet 11-18-2009 04:35 PM
00000000000000000
00000000000000000000000000000
plumber Jim 11-18-2009 10:01 PM
can you use a 2" x 1 1/2" coupling with a trap adaptor that goes inside the 1 1/2" fitting? will that give you enough room?
maxfischersweet 11-19-2009 09:56 AM
0000000000000000000000000000000000000000000000
md2lgyk 11-19-2009 01:10 PM
Originally Posted by maxfischersweet (Post 354882)
so what should i do, and why dont they make a 1 and 1/2" trap adapter that fits inside of a 2" pipe. if they do let me know where i can get it, if they dont, thats seems pretty stupid.
thanks
Unless I'm misunderstanding, what you're looking for is a common plumbing part available most anywhere. I bought one at Home Depot (or maybe it was Lowe's) just the other day.
maxfischersweet 11-19-2009 04:10 PM
plumber Jim 11-19-2009 11:33 PM
I have never seen a trap adaptor that will go into 2" all the fittings will go on the pipe not in it. what you can do is cut the 2" pipe down below the floor level with a inside cutter or a dremel so that when you glue on the 2" x 1 1/2" coupling it will be flush with the floor, Then glue the trap adaptor that is designed to go inside the 1 1/2" fitting.
