1 1/2" Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2010, 03:30 PM   #1
1 1/2" shower drain
i am going to be putting in a new shower pan and when the old one was removed I discoverd that the shower drain pipe is only 1 1/2". I never had a problem with the drain when I was using the shower so is it necessary to replace with 2"? If not, what is the best way to tie in to the 2" Oatey PVC Drain for Tile Shower Bases?
tlynn is offline   Reply With Quote
Old 02-25-2010, 07:30 AM   #2
Since you are redoing the shower, tecnhically, it needs to brought up to code(2"), to where it connects to the main. But there are reducing fittings available. Install a 2" trap as needed, then neck down to 1 1/2. But that will become a constant clog point.
Old 02-25-2010, 10:09 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
In my opinion that will be worse than leaving it 1-1/2. Code does not allow this at all.
You need to crawl underneath and see if your shower drain is visible below. Follow it back to where it intersects another pipe and take a picture for us.
Journeyman Plumber
Old 02-25-2010, 06:09 PM   #4
Rewards Points: 352
reduction in size is bad juju
plumberinlaw is offline   Reply With Quote
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 10:30 AM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 01:49 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 06:44 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
