Yellowjacket Nest - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 08-08-2013, 02:40 PM   #1
Yellowjacket Nest
Ok, long story short is that we currently have a yellowjacket nest in our wall with two entrances. One is, obviously, outside while the other is in the laundry room.
My father is very much a DIY guy and so doesn't like the idea of hiring someone to get rid of them. He tried to seal up both ends of the nest but that hasn't been effective at all due to the nature of the ground they've burrowed into outside.
So we've since taken to poisoning both ends of the nest which is going quite well in the laundry room since I regularly have to clean up yellowjacket corpses. However, I'm not sure how well it's going on the other end even though there currently seems to be no activity.
Are there any suggestions you guys might have?
Aesir is offline   Reply With Quote
Old 08-08-2013, 03:23 PM   #2
Too Short? Cut it Again!
First teach him three things. Jellow jackets are of the hornet family. Unlike bees that lose their stingers, jellow jackets, unless the stingers get yanked out somehow, can sting multiple times.
Yellow jackets are neither bees nor wasps. They are hornets.
It will not hurt that bad unless he is allergic, the sting and limb swelling will go down.
I've been stung by lots of things, and even some people so I do not know for sure. I have been swatting yellow jackets off my food in most US states at different times for decades and have never been stung by one. I do know people who messed around two close the colony and the queen (she is in your wall I bet and sent them out to defend) and ended up in the hospital looking like something out of a science fiction film.
Maybe you will get lucky with over the counter pesticides. I would have the yellow pages or Google bookmarked to exterminators though.
Old 08-08-2013, 08:26 PM   #3
Rewards Points: 1,456
It might be cheaper to DIY this, but it can also be extremely painful. The later it is in the summer season, the more potent, and vicious these little monsters can become.
A relative of mine ran over a nest with his riding mower.
15 minutes later he was dead from several hundred, if not a thousand, stings.
ktkelly is offline   Reply With Quote
Old 08-08-2013, 09:13 PM   #4
DIY staff
Rewards Points: 7,174
Use Sevin dust---works well .
Do be careful----I was nearly killed by those ---thanks to the paramedics I was able to start breathing again.---
Old 08-08-2013, 10:14 PM   #5
Gymschu's Avatar
Rewards Points: 482
I'd call Billy (or a local version of him) and call it a day. It can't be too expensive to rid your home of one yellow jacket nest.
Gymschu is online now   Reply With Quote
Old 08-08-2013, 11:34 PM   #6
Love Billy his momma en em. Great show.
Found this. See especially the prevention section. Obviously it is a pest control site but good advice.
http://www.worldwidepest.com/yellow-jacket
ktelly one of the friends I mentioned ran over a nest/colony with a lawn mower and ended up in the hospital. Fall. Vibration must have set them off for some reason. It was most likely not the first time he mowed over them.
Old 08-08-2013, 11:43 PM   #7
Some have found these hornets buzzing around to be a nuisance too. A few have pushed things to far to the point they have let loose with multiple stingers too. Quite efficiently deadly.
Old 08-12-2013, 04:08 PM   #8
Mold!! Let's kill it!
Rewards Points: 2,012
Yeah. The pesticide for these is a little out of reach for most. And the ones who can afford it usually end up with swarms of them to deal with.
Old 08-13-2013, 10:44 AM   #9
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
If the posted suggestions don't help, and you are determined to DIY you might procrastinate until fall.
Cold temps will make them sluggish and easier to deal with, or just wait until winter when they're dormant and you can open up the wall.
The Following User Says Thank You to Blondesense For This Useful Post:
oh'mike (08-13-2013)
Old 09-30-2013, 11:34 PM   #10
Rewards Points: 266
Is opening the wall the best way to deal with them? This is the first year I've had a problem with them getting into the wall under the siding and in two areas. I have been hitting the entrances wasp spray which kills some of them. I've been thinking about sealing the entrances with caulk.
Jim F is offline   Reply With Quote
Old 10-01-2013, 08:30 AM   #11
DIY staff
You need to be sure they are dead before sealing up the holes---
Can you put some Sevin into a squeeze bottle and get the powder right into the hole?
Jim F (10-01-2013)
Old 10-01-2013, 07:18 PM   #12
Rewards Points: 1,062
Wasps and hornets are in the same Genus. Its like all the foxes (a red fox is a fox, and a grey fox is a fox, and an arctic fox is a fox same genus, but theyre ALL foxes).
Hornets AND wasps are BOTH in the Wasp genus. Yes, different species, of course. There is no "hornet" genus.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 10-05-2013, 04:50 PM   #13
Rewards Points: 131
lol
thank you....
"bees" - the stinger is a 1 time use.
"wasps" - the stinger is a weapon, and can be used over and over again.
Chokingdogs is offline   Reply With Quote
Old 10-07-2013, 01:02 PM   #14
I had an issue like this last year they found a small opening under my siding into the basement ceiling joists. I couldn't get spray up under the siding and into the hole so I had to cut the sheet rock.
The small hole in the wall was my test hole to see if it was in the wall and I stuck my finger in there to pull the sheet rock out and I got stung but that was the only one.
I just slowly removed sheet rock until the hive was exposed and then I used my shop vac to remove the hive. The hive was about the size of a basketball. You could hear them buzzing but I didn't have a renter in the basement so nobody knew they were there.
dabeast is offline   Reply With Quote
Old 10-07-2013, 01:06 PM   #15
Rewards Points: 736
Just don't leave it unchecked for too long...
TheBobmanNH is offline   Reply With Quote
Whoops! I disturbed a bird nest r0ckstarr General DIY Discussions 26 07-23-2013 11:12 PM
How to Install NEST thermostat with Trane Axiom Water-Source Heat Pump momo9864 HVAC 1 05-22-2013 10:19 AM
Bird nest advice fetzer85 Off Topic 9 05-09-2013 04:40 AM
Nest 2nd Generation Brian1080P HVAC 15 01-02-2013 08:35 PM
WASPs under our deck.... diyntn Pest Control 40 01-01-2010 10:12 AM
