Wood Fungus - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 11-17-2010, 12:25 PM   #1
wood fungus
my hardwood floor is disintegrating as well as a couple of cabinets falling off the wall. new soft spots are showing up in other rooms on the hardwood. the trim around a window is soft also. the house used to be stucco. it was torn out and visibly rotted wood replaced. the house was termited about 5 years ago before this started. where can i go to get a piece of the porus wood checked to find out whats going on
susan mccurry is offline   Reply With Quote
Old 11-18-2010, 10:14 AM   #2
pest control operator
Houses that were improperly "stuccoed" or "Exterior Insulation Finishing Systems" installed wrong usually have more than one problem. Termites, carpenter ants, and pervasive wood rot/fungus go together. The termites may be back in spite of treatment. Taking a piece of wood somewhere will get that piece diagnosed, but if multiple problems exist then you will be missing potentially important information about your house. I suggest hiring a structural engineer to do a thorough assessment of your structure. They will be objective as they do not do repairs; they are in the information business. It will be expensive, but my sense is that much is wrong at your house. Keep us posted.
PAbugman is offline   Reply With Quote
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood Fungus, Will Timbor Solve this or ? twilightcall Building & Construction 4 06-05-2008 03:09 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
