Wood Boring Wasp? - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 05-31-2013, 02:04 PM   #1
Rewards Points: 590
Wood boring wasp?
Is this a wood boring wasp, or something else?
It's in the underside of one of the 2x2s that make up my deck handrail. There is a pile of sawdust underneath.
operagost is offline   Reply With Quote
Old 05-31-2013, 02:20 PM   #2
i had something similar and it was carpenter bees. if the hole is exactly 1/2 inch in diameter that might be what you have.
Old 05-31-2013, 02:25 PM   #3
Rewards Points: 13,228
There called boring bees. Just shoot some wasp killer in the hole to kill the bee and the larvi that's inside the hole.
Old 05-31-2013, 02:26 PM   #4
Rewards Points: 590
Makes sense. Any suggestions for what to kill them with?
Old 05-31-2013, 03:09 PM   #5
Rewards Points: 590
I have deltamethrin spray I was using for the carpenter ants. My research has found that powder might be better, so it'll stick to them as they walk out, but I'll try this.
Old 05-31-2013, 05:41 PM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
no, they are carpenter bees
Old 06-01-2013, 10:16 AM   #7
Rewards Points: 79
Carpenter bees can be a problem, especially if the moisture content of the wood is adequate.
One hole is not a good indication of what the wood destroying insect is.
If you have a carpenter bee problem, you would have a bunch more holes and would see large black bumble bee like bees visiting the holes. They drill a hole, lay an egg, pack with leaves, and repeat until full. A 2x2 is so small that it confuses me. The carpenter bees I have seen like larger wood, like, RR ties, joists or siding. Are there other areas being attacked?
You can treat the hole, then seal it. There are repellant over the shelf pesticides that would help limit where the carpenter bees are drilling. Some of those have almost a year long residual.
gobug is offline   Reply With Quote
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 04:14 PM
boring hole in a wood pole rorionstar General DIY Discussions 3 04-03-2010 11:16 PM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
