Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 11-19-2008, 11:02 AM   #1
What type size mesh to keep out rats/mice?
I'm looking to get some wire mesh or screen to keep out mice and rats. What size mesh should I get? What is the best way to secure it? Can mice and rats dig under it (we have sandy soil)
darsunt is offline   Reply With Quote
Old 11-20-2008, 07:19 AM   #2
bofusmosby's Avatar
I am assuming that this will be for the crawl-space at the foundation. I have tried regular 1/4" mesh screen, and they just chew right through this. I would use the lath screen, also called carpenters cloth. It is a lot heavy'er, and more difficult to chew through. As far as digging under, you might want to use some pieces of rebar, and use wire to tie this into the bottom edge of the wire mesh. Bury the bottom edge down about 6-8", just in case some critter tries to tunnel under. The wire mesh will be galvanized, so even if it does rust, it should last for quite a while.
bofusmosby is offline   Reply With Quote
Old 11-20-2008, 09:34 AM   #3
RippySkippy's Avatar
sometimes the carpenters cloth is also known as hardware cloth
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 11-21-2008, 11:35 AM   #4
Bug Expert
Bugzilla's Avatar
Just remember this: rats can get through a hole the size of a quarter and mice through one the size of a nickel. To learn more about these varments, check out the pest library @ LINK REMOVED . There's some good info there.
Bugzilla is offline   Reply With Quote
Size of whole house fan needed Doug Crf General Discussion 20 02-26-2011 12:29 AM
Nail size and Type ????? mjkpainting Carpentry 7 11-21-2008 03:06 AM
What type / size screws for subloor project... scheenstra Building & Construction 1 05-17-2008 09:22 PM
Wire size and type in Rigid Metal Conduit Al the Diy guy Electrical 5 02-05-2008 09:31 PM
Plumbing type and size marlenecapps@cox.net Plumbing 2 10-14-2005 12:42 PM
