What Pesticides Or Termicides Do You Guys Suggest? - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 03-15-2017, 08:49 AM   #1
Rewards Points: 238
What pesticides or termicides do you guys suggest?
I have a 3-level townhouse with a walk out basement and it was built in 2004.
Was wondering what pesticides or other things I should use around the perimeter, as well as inside the house? Where can I get those specific products?
I don't have any specific problems or concerns, but want to do it as a preventative maintenance.
Thanks so much for the help and input.
helpme81 is offline   Reply With Quote
Old 03-15-2017, 10:48 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,718
Re: What pesticides or termicides do you guys suggest?
Any particular species of pest you are looking to control?
Best thing to do is make sure the house is well sealed and you don't have soil too close to wood framing.
Old 03-15-2017, 11:17 AM   #3
Rewards Points: 238
Spiders, but nothing in particular. Termites if they can cause problems too?
Old 03-15-2017, 04:00 PM   #4
Rewards Points: 1,274
Spiders go where the food is - which is other insects. If you get rid of the spiders, get ready for an onslaught.
LawnGuyLandSparky is offline   Reply With Quote
Old 03-15-2017, 04:08 PM   #5
Rewards Points: 238
What about termites ?
Old 03-16-2017, 07:10 PM   #6
Rewards Points: 454
termites and ants- Imidocloprid. Forget pesticides for spiders, they dont work.
papereater is offline   Reply With Quote
Old 03-16-2017, 08:23 PM   #7
Rewards Points: 238
Thanks, how often that should be done? Where do you buy this Imidocloprid?
Old 03-17-2017, 12:42 PM   #8
The public does not have access to the effective chemical programs that the professionals use. Your best bet is to buy some over the counter stuff from the hardware or home center.
By 2004 when your townhouse was built, it should have already had termite shield installed wherever your wood meets your concrete.
Old 03-17-2017, 07:12 PM   #9
Rewards Points: 454
Heres a good place, and not too $$$:
https://www.keystonepestsolutions.co...P_ohoCk4nw_wcB
The key here is this is a NON REPELLENT, which means it works as a delayed killer, and insects can not notice its source/effect until its too late.
Dont be discouraged by some claims that only the pros have access to good effective pesticides. True, some are available only to pros, but Imidocloprid or termidor are equally effective. DIYers can buy both.
Old 03-20-2017, 05:32 AM   #10
Rewards Points: 32
Termite known as white ants, termites can ruin all the wooden material in your home.
erikjamison is offline   Reply With Quote
Suggest me Best Landscaping brockton General DIY Discussions 1 02-12-2014 05:32 AM
Hi Guys AtYourDoorFloor Flooring 1 06-03-2010 06:27 AM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
Basement is Framed- Thanks Guys mjkpainting General DIY Discussions 16 05-05-2009 09:25 AM
What do you guys do to save on your Electricity bill? (2009 Edition) ehoez Electrical 47 04-10-2009 06:53 AM
