Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 07-26-2011, 07:51 AM   #1
What kind of insect did this?
Howdy all. I am doing some work at my house and found tunnels inside several studs. No dust piles or insects, just tunnels. Some of the tunnels have what appears to be saw dust in them but it's hard. It almost looks like wood filler. The studs are all structurally sound, not soft at all. The attached picture shows an example.
Some are in load bearing walls so they are not easy to replace. I live in Michigan. The damage looks to be quite old... I think. The house itself it old - 50+ years.
1. What insect likely caused this?
2. How likely is it that the insect is still around? I haven't seen any bugs at all.
Thanks - Don
xycarp is offline   Reply With Quote
Old 07-26-2011, 08:01 AM   #2
Super Moderator
I'm not a bug man---just an old carpenter.
The way the channels are exposed looks to me like the damage was in the log before the studs were cut.
If so the kiln drying killed the bugs long before the house was built.
I don't see a problem--just ugly studs.
Having a bug man come out to verify would not be a bad idea,However I've seen that many times with new lumber----It wasn't a problem.---Mike---
josall (07-26-2011)
Old 07-26-2011, 08:11 AM   #3
pest control operator
It is from a wood-boring larvae/beetle. Very likely been there a long time; oh'mike's advice is good. The sawdust they make is called "frass" and they use it to pack the oval opening prior to emerging. Their gestation period can be years, especially if in an unheated building. It's likely that kiln drying did kill them and no re-infestation took place. Oftentimes they don't re-infest anyway due to the wood changing it's moisture and nutrient content over time.
They do make oval shaped holes though. The longer galleries indicate that the milling process exposed them, as oh'mike points out.
PAbugman is offline   Reply With Quote
what kind of wye do I need? graysqwrl Plumbing 6 06-22-2011 05:23 PM
Looking for a kind of pest killer spray userid Pest Control 1 05-04-2010 08:06 AM
New kind of weed in lawn? VelvetFoot Landscaping & Lawn Care 9 11-14-2009 11:11 PM
What kind of breaker TaazKareem Electrical 22 09-26-2008 11:03 PM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 01:54 AM
