-   Pest Control (http://www.diychatroom.com/f51/)
-   -   What kind of insect did this? (http://www.diychatroom.com/f51/what-kind-insect-did-112002/)
xycarp 07-26-2011 06:51 AM
Howdy all. I am doing some work at my house and found tunnels inside several studs. No dust piles or insects, just tunnels. Some of the tunnels have what appears to be saw dust in them but it's hard. It almost looks like wood filler. The studs are all structurally sound, not soft at all. The attached picture shows an example.
Some are in load bearing walls so they are not easy to replace. I live in Michigan. The damage looks to be quite old... I think. The house itself it old - 50+ years.
1. What insect likely caused this?
2. How likely is it that the insect is still around? I haven't seen any bugs at all.
Thanks - Don
http://farm7.static.flickr.com/6137/...a59742ae_b.jpg
oh'mike 07-26-2011 07:01 AM
I'm not a bug man---just an old carpenter.
The way the channels are exposed looks to me like the damage was in the log before the studs were cut.
If so the kiln drying killed the bugs long before the house was built.
I don't see a problem--just ugly studs.
Having a bug man come out to verify would not be a bad idea,However I've seen that many times with new lumber----It wasn't a problem.---Mike---
PAbugman 07-26-2011 07:11 AM
It is from a wood-boring larvae/beetle. Very likely been there a long time; oh'mike's advice is good. The sawdust they make is called "frass" and they use it to pack the oval opening prior to emerging. Their gestation period can be years, especially if in an unheated building. It's likely that kiln drying did kill them and no re-infestation took place. Oftentimes they don't re-infest anyway due to the wood changing it's moisture and nutrient content over time.
They do make oval shaped holes though. The longer galleries indicate that the milling process exposed them, as oh'mike points out.
