What Did This To My 4x4 Deck Support? - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 10-24-2008, 07:28 AM   #1
What did this to my 4x4 deck support?
I was doing some fall clean up and noticed that something dug a hole next to one of the 4x4 posts under the deck and chewed a hole the size of a baseball into the support. I have no idea what could of done this. Any thoughts?
Here are some pics:
cwest94 is offline   Reply With Quote
Old 10-24-2008, 07:38 AM   #2
the Musigician
DangerMouse's Avatar
the pics look to me like something DUG the hole. is the wood rotted? probably a groundhog or other digger trying to get under your home to make THEIR home. plug the hole.
DM
Old 10-24-2008, 09:49 AM   #3
home improvement guru
aaron.klimchuk's Avatar
Definitely plug the whole asap and keep an eye on it. You might want to have a deck contractor come check it out to make sure it's still structurally sound.
Last edited by AtlanticWBConst.; 10-25-2008 at 07:48 AM. Reason: Site Rules Violation: Business Web link Removed
aaron.klimchuk is offline   Reply With Quote
Old 10-24-2008, 11:15 AM   #4
Yes, something dug up about a foot of earth and then chewed right through the wooden post. The post is at the far end of the deck away from the house and I dont think whatever it was could chew through concrete (or can they?) to try and get into the house. I've never seen anything like this before and I checked all the other posts under the deck and they are fine. The hole in the post is about the size of the 4x4 itself, so it is going to give out. I'm not to worried right now since the deck is only a foot off the ground and no one will be out there during the winter. I just want to know what could of done this to try and prevent the other posts from getting attacked. : (
Old 10-24-2008, 11:30 AM   #5
the Musigician
is the post rotted? can you dig out pieces of it with your fingers? if so, it's dug. i don't think groundhogs will chew them, nor coons or rabbits i don't think. do you have beavers nearby? fill the hole and watch it and the surrounding areas for fresh digs. if that same hole gets dug, see if it looks like it's dug IN or OUT. the critter may be in there comfy already and will push the dirt out. some mothballs or other repellent might be a good idea too.
DM
Old 10-24-2008, 04:32 PM   #6
it's chew'n holes
Chipmunk Control ?
ViSta is offline   Reply With Quote
Old 11-21-2008, 12:36 PM   #7
Bug Expert
Bugzilla's Avatar
That post had to be softened (probably by moisture) before any animal could've gnawed into it. I would suggest that if all of your deck posts are in contact with the soil, that you cut them off above ground and install concrete footers under them.
Bugzilla is offline   Reply With Quote
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
Need help with a deck to support a new spa! kellymac Building & Construction 5 06-12-2008 01:32 AM
Support posts for 12' high deck hotchkiss Remodeling 3 09-05-2007 07:32 PM
Deck support beam has twisted Brian Ward Building & Construction 5 07-27-2007 12:03 PM
How to make existing deck support more weight? tigerbalm2424 Building & Construction 7 04-22-2007 01:12 AM
