Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 06-28-2009, 12:47 AM   #1
Default WASPs under our deck....
We have a bad problem with wasps building under our deck. I am removing the decking and have already gotten stung. I have covered the top in plastic and bombed (just a bug bomb, couldn't find a wasp bomb) to no avail. They still are swarming underneath.
I have managed to get 1/2 of the decking off. But the nests are still under there. I think I'm gonna attack it from afar better. A long pipe as a pry bar, rather than the standard pry bar.
Two questions:
1-do you have any suggestions on how to kill them before I take the decking off?
2-Is there anything that I can do as I redeck this thing, to prevent them from getting this bad again? We were thinking maybe putting landscape cloth underneath the decking planks. ?? I dunno, just shootin in the wind there.
Thanks,
Mark
diyntn is offline   Reply With Quote
Old 06-28-2009, 12:55 AM   #2
I used to live where wasps were common to get under the eaves of the house and such - I kept a couple spray cans of wasp killer spray, which would shoot a directed spray 6' or better. Knocked them right down.
Long term keeping them from coming back I dunno - maybe the commercial exterminator services.
Old 06-28-2009, 01:25 PM   #3
Extreme DIY Homeowner
Scuba_Dave's Avatar
For a insecticide bomb to be effective the entire are must be tented in, sides & all. Longer pry bar just means it will take them about 1 second longer to sting you
How far off the ground is the deck?
They will usually not fly in between the planks
They would have to crawl down - most will not do that
So enclosing the sides of the deck will eliminate their ability to fly in
Butt the new boards as close together as possible
As they dry they will leave a small gap for water drainage
Old 06-28-2009, 02:19 PM   #4
rwa
rwa's Avatar
you could paint the bottom side of your deck blue
rwa is offline   Reply With Quote
Old 06-28-2009, 02:24 PM   #5
why?
Old 06-28-2009, 03:00 PM   #6
Household Handyman
I have a deck that is four (4) feet off the ground and have the wasp problem every year when it gets hot. I have one of those foggers that works off electricity, some work off the small propane tanks. The bug zapper liquid that goes in this machine will kill the wasps. The bottom of my deck is enclosed with lattice and I wait until just before dusk, and it's not windy, as this seems to be when they come home. I fog this area really good, walking around to ensure good coverage, the fog comes up between the spaces in the decking boards as it fogs, and gets any living creature under there. Yes, I have to do it every two-three weeks, but it's the only thing I've found that will kill them. I spray my bushes near the house to keep down mosquitoes and other stuff also. Good Luck, David Please post your general location.
Old 06-28-2009, 03:30 PM   #7
Scuba_Dave's Avatar
Originally Posted by diyntn View Post
why?
Refer to his avatar
I have a fogger, works great
Neighbors thought my house was on fire one year
Old 06-29-2009, 09:32 AM   #8
Originally Posted by Scuba_Dave View Post
Refer to his avatar
Oh..LOL..I see.
I have finally, with the help of 3 people, (I got stung once) got the boards removed. OMG....It wasn't a few wasp nests, it was a wasp INFESTATION>...
There were no less than 25-30 nests under there, most still "LIVE". I can't believe we haven't been stung more.
We didn't go out there a whole lot anyways.
So, I did get all the old boards off.
Now, I'm just troubled with how to make sure I've done all I can to prevent this recurring. It must be location. It's on a side of the house with no shade and gets a lot of sun. They must love that setup.
Old 06-29-2009, 03:10 PM   #9
Stuck in the 70's
Blondesense's Avatar
There is an old wives tale that says if you paint your eaves sky blue wasps will not build nests under them. The idea being they see the sky blue paint as sky and not somewhere to build a nest.
No idea if it is effective or not.
Old 06-29-2009, 03:56 PM   #10
You know, seems like I've heard that before, but had forgotten.
But..under the deck it's dark...
maybe dark clouds might keep em away.
But, I've read a lot online about this and it appears this is an ongoing problem.
A few are not a problem, but an INFESTATION like we had has got to be stopped before it get's that bad again.
Guess it's going to take me just hunkering down and looking underneath the deck on occasion.....
Old 06-29-2009, 09:55 PM   #11
rwa
rwa's Avatar
another thing I have heard thru the years is to mix lime in the paint
Old 06-29-2009, 10:00 PM   #12
Scuba_Dave's Avatar
Well the back of my house will be blue - maybe find out
Old 06-29-2009, 10:33 PM   #13
Yoyizit's Avatar
If you knock the nest down they will abandon it within a morning.
A small torch or candle at the end of a 16' piece of thin lumber will do wonders for them. They don't see or think that well, believe me, so they will never think to follow the board. Don't try this with yellow jackets, though.
They fly with their stinger down so if you bat them out of the air be sure to strike from above. They fly slowly. If they then land on soft earth stepping on them usually only works temporarily.
If you jam a 2x4 into their nest it will immobilize most of them until you remove the 2x. Then they will be looking for revenge and most of them will be perfectly capable of flight. Half the fun of this is watching the bystanders scatter (and you along with them).
If you get stung under your eye it will take a day or so for the swelling to subside.
Old 06-30-2009, 09:04 AM   #14
I try to use the garden hose, longer range, under a deck could be tough though, not sure if same with wasps, but they ( can't find they) say the bee's dont' return to same nest each year, might be why you had so many nests.
If stung on eye lid, takes couple days for swelling to go down.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 06-30-2009, 02:03 PM   #15
Stuck in the 70's
I thought someone here mentioned cold weather but I don't see it now.
They do seem to be sluggish or less active when it is cold so you may want to plan your major annual maintenance attack when the temp is in the 50's.
If you want to kill as many as possible you might also consider waiting until late dusk when they have all returned for the night. That way you get most if not all of them rather than having a lot of homeless guys buzzing around after you destroy their hive.
If they are yellow jackets, Move.
More On This Topic
How to Treat a Bee Sting
How to Treat a Bee Sting by Expert Village
Hello, my name is Dr. Susan Jewell. Now in this clip, I'm going to talk to you about bee stings, because bee stings are very common in the summertime during the year. And when you go out in the garden, or go into the woods for camping, you can get a high... Read More »
Although ground digger wasps are beneficial for controlling pests, the wasps are curious about anything around the nest and may sting you. There are several steps you can take to rid your lawn of these insects. Read More »
Anaphylactic shock is a life-threatening medical condition where a severe allergic reaction can cause respiratory and pulmonary distress, which can eventually lead to death. By knowing how to help someone who is suffering from anaphylactic shock, you may... Read More »
Hi I'm Marcia Matcham and I'm here speaking on behalf of Expert Village. I like to gather things to use in my paintings. A lot of times I like to do nature still life that is what I call them and my brother-in-law gave me this beautiful turkey wing after... Read More »
Here's an example of an anaphylactic reaction and the correct treatment that should occur. Here a young male who's just got stung by a bee. First thing he does is he notices that it's obvious it's a bee sting. First thing he wants to do is remove himself... Read More »
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 07:07 PM
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 09:46 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 01:17 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 05:37 PM
Roof used as a deck - what is a good approach rogersor Roofing 3 09-19-2007 03:05 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
