Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 07-03-2009, 08:22 AM   #1
Wasps under deck..Part II.
I had posted this about wasp prevention under a deck, but had some other thoughts and questions:
There is one spot, an open space, runs the length about 2-3 inches wide between two bottom supports that they seem to enjoy building in more than other spaces underneath.
What can I put in there to prevent them, or anything else for that matter, from building?
Also, I am going to put landscape cloth down underneath the boards OVER the runners. My thoughts there is that it could keep them from flying up between the deck boards and stinging us like they have. They would still build under there, but have to flyout the sides of the deck to get out.
Anybody else got thoughts there?
diyntn is offline   Reply With Quote
Old 07-03-2009, 09:34 AM   #2
Xtreme DIY'r
Buy some metal window screening & put it in underneath
Old 07-05-2009, 12:40 PM   #3
Stuck in the 70's
Blondesense's Avatar
You might consider expandable foam insulation in the problem spots.
I also like Dave's idea of screen.
Be sure to keep drainage in mind. Anything attached to (or under) the deck will most likely also catch dirt and debris which will hold water/moisture and shorten the life of your deck.
Old 07-06-2009, 07:53 AM   #4
DIYer
Buy some demon WP and kill everything that comes within 10 feet of your house. The nuclear option. :P
Gigs is offline   Reply With Quote
Old 07-20-2009, 09:54 AM   #5
I have had the same problem.
I bought a product called waspinator sold at hardware stores. At first I didn't think it would work but tried it out. It looks like a larger wasp nest. Wasps are territorial and will not come by as they think there is a wasp nest already in the area. I have also sprayed wasp nests and left the nest behind, simiklar effect as the waspinator.
Enjoying bbqs and meals outside without concern of the wasp.
dotmatrix is offline   Reply With Quote
Old 07-28-2009, 06:13 PM   #6
Find the nest(s) and if you want to go out and buy some nasty crap to spray on the nest knock yourself out! But if the nest is visible and accessible cool, go chill out and have a beer or two until lets say midnite or so. Now, if your not sleepy like all the wasps are in the middle of a cool nite you douse the nest with rubbing alcohol which will shut them down right now! Then glove the nest removing it to an area in which you can safely practice your pyrotechnics.
This was the perfect method I used for a huge ground nest I stumbled upon last year, Failsafe!!! Yes, the rubbing alcohol is very manageable when lit with caution. I almost want to say the whole nest should perish just by the temperature shock and lack of oxygen when doused with the rubbing alcohol.
My Ziploc bag method is a bit more of a crazier way to eliminate them so I will only divulge that info to the fearless so to speak!
woobiken is offline   Reply With Quote
WASPs under our deck.... diyntn Pest Control 40 01-01-2010 10:12 AM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
enclosing part of deck Jeremy Hillary Boob, PhD Building & Construction 2 06-19-2009 10:59 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Worst part of building a deck?? Ler0y Jenkins General Discussion 8 06-09-2008 04:07 PM
