Treatment For Lumber In New Construction - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 03-03-2013, 02:30 PM   #1
Rewards Points: 31
treatment for lumber in new construction
is there a chemical/solution to treat lumber and aid in repelling insects when framing house?
jbillups is offline   Reply With Quote
Old 03-03-2013, 03:14 PM   #2
bluwood.com seems to be the norm but if you want something to apply yourself then that isn't an option.
House2HomeLLC is offline   Reply With Quote
Old 03-03-2013, 03:20 PM   #3
Rewards Points: 13,250
If it's built right and the fountation gets pretreated you should not need to treat the wood.
If you insist then you can treat it with this or just get the rough framing up and any extermiator can do it for you.
http://www.doyourownpestcontrol.com/timbor.htm
storageman (04-18-2013)
Old 03-03-2013, 03:23 PM   #4
Phone didn't let me finish. Bora care can be bought as a do it yourself product and there is a blue tint you can purchase seperately in order to give it a color so you can see where it has been applied. This is what I use when I build sheds for people so I don't have to pre order the wood.
Old 03-03-2013, 06:13 PM   #5
Rewards Points: 1,062
Or you can make your own- all that is is some 20 Mule Team Borax (from grocery store), plus a dilute solution of regular anti freeze (ethylene glycol). Mix and stir , gradually adding the borax til it doesnt dissolve anymore (saturated). Paint it on.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 03-03-2013, 06:30 PM   #6
Still trying to figure out why you think you need to go to all the extra effort and expence.
Something I'm missing?
Old 03-06-2013, 01:27 AM   #7
Westies
Treatment for lumber in new construction
If you use any of the boric acid spray-on solutions (I recall esp. for termite repel) don't do what a pest control firm did to us when I was new to housing stuff.
So the worker of this well known pest chain service goes to our basement and sprays the solution up at the plate and ring board of our foundation (atop concrete walls). Of course he coated the nearby copper pipes of our hydronic and plumbing system and it took me awhile to see the corrosion (esp. at joints of course), and washing with mild bases (baking soda paste) did not stop the degradation. I replumbed within 3 years.
The house wasn't built with the zinc coat joist hangers of today but I assume the boric acid would eventually damage those and fasteners too.
Careful, chemistry can bite!
Westies is offline   Reply With Quote
Old 04-18-2013, 02:35 PM   #8
DIY & Installation
I would only use wood that is manufactured by Louisiana Pacific. They use a special process that makes the wood siding resistant to nasty insects, termites and moisture. For more information on LP and the boric acid, visit the Louisiana Pacific website. I found this link here for LP siding used in storage buildings.
storageman is offline   Reply With Quote
Old 04-19-2013, 04:43 PM   #9
Too Short? Cut it Again!
I liked treating walls of renovations with bora care or something like it. It is inexpensive and can help with things like roaches and ants. It certainly does not hurt anything to add it. As mentioned, the primary ingredient is Boron or Borax is one other trade name. I think Abatron still sells it but so do many others. Bora care comes as a liquid concentrate. Buying the ingredients in powder form and mixing your own is much cheaper if you want to spray it on. Otherwise you can just dust cross members.
Good old cheap plastic bottles of roach powder are mainly boron too. Diatamaceous earth used in swimming pool filters sprinkled on cross members is another possibility. It is cheap too.
Careful with run-off. Boron in high concentrations can render soil sterile for a long time. It's use an herbicide (it is one thing that actually works on Creeping Charlie) is banned in some states for this reason. Otherwise, it is a natural occurring mineral.
Window Sill Rot, New Construction Replacement? mpg9999 Windows and Doors 8 11-18-2012 08:08 AM
B-12 Chemtool versus SeaFoam DrHicks Automotive Repairs 16 10-01-2012 09:57 PM
Books that teach the basics of construction - recommend them to me? costafinkel Building & Construction 13 08-05-2011 12:32 AM
Soft Hearted Construction Guys Wildie Building & Construction 0 11-29-2010 07:05 PM
Termite Treatment Chemicals TBear Pest Control 6 10-05-2008 06:35 PM
