Treating Soil Under Concrete With Termidor - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 10-27-2014, 11:33 AM   #1
Rewards Points: 30
Treating Soil under Concrete with Termidor
Noticed most DIY folks simply pour Termidor through holes they've drilled into sidewalks and patios (using a funnel) to treat the soil underneath. The Pros use rodding equipment and inject the Termidor under pressure to get a better fill. Can anyone recommend a relatively inexpensive manual pump of some kind that can be used to inject the Termidor? Realize it won't be as effective as the rodding equipment, but it certainly has to be better than simply using a funnel.
Thanks!
HomeGuy2 is offline   Reply With Quote
Old 10-27-2014, 11:40 AM   #2
Rewards Points: 238
you could always approach a exterminator and tell them you have the holes pre drilled and just want them to rod it with termidor for you, see if they will give you a discount for doing the hard work.
or
there is a nice selection of equipment here.
http://store.doyourownpestcontrol.co...mite-equipment
Pest Control Bellingham, WA
Gustavas is offline   Reply With Quote
Old 10-27-2014, 03:48 PM   #3
Rewards Points: 12,876
Why would you even be treating a sidewalk?
Old 10-27-2014, 04:14 PM   #4
When my house was treated I had to remove the first few planks of my deck to access the ground below and the old concrete stoop under there. Holes were drilled in the basement perimeter just inside the footings about every 12 inches. Holes were drilled through the concrete porches, the stoops and the garage floor. A 6 inch deep trench was dug around the perimeter. The principal was to build a solid barrier of termicide with no gaps. 200 gallons of concentrated chemical was used for 1100 sqft ground plan. I don't know what the diluted total was. Termicide was injected about every 12 inches up the height of the foundation, the porch holes and the interior footing holes. It was fairly large truck mounted pump. Why the porches and sidewalks adjacent to the house? That is where the termites entered my house between that little gap, unseen. It all went well except for an 10x4 inset concrete porch surround by three wall. Guess where they returned . Cost the extermination company under their warranty, entry to fix the rim joists, sills, studs, coner posts demo and replace the porch for access. Before the porch slab was poured they dumped another gallons of termicide. I haven't seen a termite for 12 years. Yes, it is important to get under the side walks an porches. of course I will probably end with some nasty disease living in that moat of termicide
More power to you for doing it yourself . There was nothing overly complex about the work. It can be done I am sure, but is no small amount of work. It would have taken me weeks. Good luck. I would get the proper equipment
jimn01 is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Need of some help with concrete driveway & patio? imola ghost Concrete, Stone & Masonry 25 04-05-2012 10:03 AM
Concrete prep for outdoor tile onthejob Concrete, Stone & Masonry 8 03-29-2012 01:34 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
Picking a foundation for shed/simple workshop Corey in NE Building & Construction 30 02-08-2010 12:34 PM
