Theres No Way To Kill Roached Down A Sink Drain, Right? - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 09-10-2013, 04:52 PM   #1
Rewards Points: 1,062
Theres no way to kill roached down a sink drain, right?
Gees, how does one control the breeding "ground" for disgusting roaches if the live in your sewer drain/pipes that travel for 100-200 feet??! They come up the drain, and crawl out of sink, then, well, you know. Yes, I can spray Demand CS around sink area, etc, but wont they just keep coming out?
Thanks.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 09-10-2013, 04:54 PM   #2
I mean, I could "gas" them- first dump bleach down there, the follow with muriatic. Resulting will be a drain pipe line full of chlorine gas. Of course, I will have to stoper up my rain........
Old 09-10-2013, 05:20 PM   #3
Rewards Points: 12
That sounds like a scene from a horror movie. They make it through the trap?
Dan
djlandkpl is offline   Reply With Quote
Old 09-10-2013, 07:25 PM   #4
Im just assuming they do- cant say 100% as I dont see thm climb out (indeed like a horror movie!), but theres 3-4 right where the sing is- Im assuming they hold their breath and 'swim" through trap. i wouldnt put it beyond them, those 350 million year old stinkers......from the cretaceous era.......
Old 09-10-2013, 07:29 PM   #5
geez- maybe I should ckeck/verify- maybe I have a stupid bottle trap instead of a regular p trap . If so, a dry bottle trap would be a good easy highway for them to come on in!
Old 09-10-2013, 07:36 PM   #6
OK. Its a p trap. BUT, the drain system does not have a regular whatchamacallit- that long tube that goes through the roof, for venting. Vent pipe(?). It has a shortened version, that is under the sink, maybe thats where theyre crawling from. sewer, through that venting pipe, avoiding the p trap....
Old 09-10-2013, 07:40 PM   #7
Rewards Points: 12
I would think that if the plumbing lines are used on a regular basis the roaches would get washed back down the pipe, especially the main line. If I had to guess, they are coming from somewhere else.
Dan
Old 09-10-2013, 07:42 PM   #8
Rewards Points: 13,300
100% sure there not drain flies?
http://www.bing.com/images/search?q=...ures&FORM=IGRE
Old 09-10-2013, 07:42 PM   #9
Rewards Points: 12
Can you post a pic of the "vent". I haven't seen the guts of an AAV but they are supposed to let air in not out. I suppose it's possible for the roaches to get out.
Dan
Old 09-11-2013, 04:16 PM   #10
Originally Posted by joecaption View Post
american cockroach. I majored in Bio.
Old 09-11-2013, 04:19 PM   #11
Good point, dj. I didnt thin of that- air should go IN, not OUT when drain is "flushed" with water. Meaning, shouldnt that be a kind of check valve setup? Geez- could they NOT be coming out of there? Why do they concentrate in sink. Moisture, perhaps.....
Update: no roaches last night, but I did spray area with Demand CS. No dead ones either. Will watch it.
Thaks,People
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 10:41 AM
After Snaking, Basement floor drain and utility sink still Bubbling & Backup bikermark1 Plumbing 2 07-22-2010 01:14 PM
Finishing basement....sink won't drain jerrydlish Plumbing 1 08-19-2009 09:36 PM
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 10:17 PM
Drain placement for sink simonb Plumbing 3 09-08-2007 02:08 PM
