Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 11-20-2012, 05:58 PM   #1
jburd964's Avatar
Termite Treatment
I recently purchased a old house to flip. The house is stick frame with shingle siding. Somewhere down the line they decided to run a chain wall around exterior and put a brick veneer over original house, without removing the shingles. The underside of house is low to ground and is pretty inaccessible. I'm repairing floors and leveling house and while I have somewhat easier access I want to trench and run sprinkler hose around the perimeter of underside of house of future termite treatments. What would hold up to the exposure to the chemicals in the termite treatment. Cost efficiently. Any suggestions?
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 11-20-2012, 06:18 PM   #2
Termite Treatment
Well that post made 0 since.
What your suggesting is just never done.
Is this your first flip?
Time to be calling some local exterminators.
Be prepared for some strange looks when you suggest doing it that way.
Old 11-20-2012, 07:49 PM   #3
jburd964's Avatar
Termite Treatment
You know if you smart asses would reply with useful information instead of dumb ass comments, these pages may have a few more participants. You can't read simple English. I know of it being Teraminx will come do for you for a small fortune. Sometimes the number of post equals the number of time someone with a legitimate question had to lesson to a dumb ass like yourself. Zero since.
Old 11-21-2012, 07:21 PM   #4
Termite Treatment
Having owned and operated a pest control business and being licensed for termites, I also do not see the sense in your plan, nor the how-to.
Accept that you have bought a termite heaven. If you do not remove the untreated wood, and eliminate all pathways of termite activity, you have bought a big task.
I would avoid any flip until you resolve a good plan on how you are going to cope.
Consider removing everything you can made of wood from the old structure. Old wood that must (&can) be saved can be injected with a boric acid gel that goes into a small hole and is absorbed by the wood. (Nisus=mfg) If done right it should protect well treated wood for 40 years, if it can be saved.
This would be a DIY cheap job. Trying anything to do with a trench and all the chemical gear and safety equipment and knowledge on how to do it does not make sense.
A negative attitude will come back on you.
gobug is offline   Reply With Quote
Old 11-21-2012, 07:59 PM   #5
Termite Treatment
I was also a licenced exterminator in the state of VA.
And still your idea and attitude to logic make 0 since.
May want to try some other DIY sites and I'm sure if you try long enough someone that knows nothing about treating for termite will think your idea is great and agree with you.
Old 11-21-2012, 09:00 PM   #6
Termite Treatment
Do a google on termite injection. It's not new, been around at least 30 years.
Fairview is offline   Reply With Quote
Old 11-22-2012, 01:47 AM   #7
jburd964's Avatar
Termite Treatment
I never said I was going to apply chemicals myself. Joe your a ****ing idiot!! Don't post back to any of may threads and listen to the man on that negativity crap..
Old 11-22-2012, 01:53 AM   #8
jburd964's Avatar
Termite Treatment
No part of house is in contact with the ground at all. IT can't be easily accessed.
Tags
bugs, pest control, prevention, termite treatment
Termite treatment jjrbus Pest Control 7 09-10-2012 07:13 PM
Which termite treatment is sufficient? gsm113 Pest Control 8 02-22-2012 10:55 PM
termite treatment gkaro Pest Control 2 01-03-2012 07:51 AM
rain after termite treatment supermaxhd Pest Control 1 04-04-2011 09:21 AM
Termite Treatment Chemicals TBear Pest Control 6 10-05-2008 06:35 PM
