Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 03-29-2012, 10:10 AM   #1
termite tenting
how do i prepare my house for termite tenting
mcintyre is offline   Reply With Quote
Old 03-29-2012, 10:34 AM   #2
termite tenting
The company doing it should be the one your asking. They should be able to even give you a written list of what needs to be done.
There the ones ultilmately liable if anything happens so they should be more then willing to give you the info.
Old 03-31-2012, 10:49 AM   #3
pest control operator
termite tenting
The fumigant being used will determine what you need to remove from the house and what can stay. It will be a function of temperature and time. Colder temps mean longer tent time. I never did fumigations on houses but in the past have done a lot of commodity fumigations on foodstuffs going overseas. Your state my have regulations and guidelines also. In Pa it would be the Dept of Agriculture, but that varies from state to state. Your main source, as Joecaption says will be the fumigators. Make sure they are experienced. If the house is not sealed well, the gas will escape through negative pressure and it won’t work and be a big waster of time and money.
PAbugman is offline   Reply With Quote
Termite wood floor as sub-floor gtimk4 Flooring 1 09-21-2011 07:30 PM
Termite exetermination tenting house. gante Pest Control 11 07-18-2010 11:44 AM
termite control nick__45 Pest Control 1 05-01-2010 12:17 AM
Termite Tenting -- Still have termites? sierra395 Pest Control 19 08-13-2008 07:27 PM
Termite Tenting DaGoomba Pest Control 2 10-27-2007 12:59 AM
