Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 12-16-2011, 12:01 AM   #1
gkaro's Avatar
termite sprays
All. A project calls for spraying all structural elements with a termiticide. Does anyone have any recommendations?
Are the ones sold at the depot or lowes diff from the comm brands?
gkaro is offline   Reply With Quote
Old 12-16-2011, 07:16 AM   #2
termite sprays
Most things available to the homeowner won't work well. Something with borax is effective if the wood is impregnated. Solutions with copper usually work, but most have been pulled from the retail market or diluted to the point of being useless. Consider a pro for this.
Old 12-16-2011, 08:30 AM   #3
termite sprays
What exactly is it that you plan on spraying? Ground, foundation, wood somethings being built out of?
Old 12-17-2011, 10:57 AM   #4
pest control operator
termite sprays
I structural elements are the wood members, than borate-based spray is what you want. Some examples are Tim-bor, Boracare. As the patent is off, there are now others as well. Look at the active ingredients; you want something that says “disodium octaborate” or close to that. This is a wood treatment only.
If soil treatment is to be done, I like the active ingredient “Fipronil” a lot.
What part of the country are you in? Would you be targeting subterranean or drywood termites or both? That will be a major factor is chemical/treatment choice.
PAbugman is offline   Reply With Quote
Old 12-17-2011, 11:07 AM   #5
gkaro's Avatar
termite sprays
Thanks for all the info.
I'm in southern Ontario Canada.
Yes its for the wood only.
Old 12-20-2011, 07:56 AM   #6
gkaro's Avatar
termite sprays
Hi. Thanks for your previous response on the termite spray. I found a guy that will do this but he suggested "dragnet" or dragon something....sounds like.
Do you know this product?
Consumer Termite Spray jonathan03 Pest Control 19 05-16-2013 09:08 AM
Termite wood floor as sub-floor gtimk4 Flooring 1 09-21-2011 07:30 PM
Termite Shield or Not Ezekiel Building & Construction 2 02-09-2011 08:53 PM
termite control nick__45 Pest Control 1 05-01-2010 12:17 AM
Need some advice on buying home termite & water damage. Mr Heshup General Discussion 1 03-29-2009 04:06 PM
