Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 02-10-2010, 12:20 PM   #1
Is this termite damage?
I already had wood rot on the window trim when I bought the house, have termite warranty/agreement, was clear but now these little holes have showed up making me suspicious...
I have not seen any other evidence of termites/carpenter ants yet but I just noticed this the other day. We do live near water and woods occasionally see a wood roach outside.
snosurfa7 is offline   Reply With Quote
Old 02-10-2010, 08:47 PM   #2
probably...take an icepick or a nut pick and probe a couple of the holes to see if they connect to tunnels or channels. If the channel is smooth (like it has been sanded = termites) termites like going with the grain of the wood... must taste better or easier to chew... the small round holes are made so they can clean out their waste from their passage ways.
Check your termite warranty... is it a repair bond or a retreat bond.. their promiss to retreat that area at no extra charge once your have made the repairs?
Big Bob is offline   Reply With Quote
Old 02-11-2010, 08:05 PM   #3
So my termite guy came by today and took a look at the wood...he says this is mostly just moisture rot with likely wood boring beetles creating those holes. He was 99% certain those were not termites given that there was no other evidence at all (sawdust etc) around the areas.
I was going to take off the trim this Spring but I'll just do it sooner now, it needs to be done either way.
thanks
Old 02-26-2010, 08:35 PM   #4
Dyoung's Avatar
Dont delay though.
We have post beetles and they have eaten out several roof rafters, thus necessitating an emergency repair on the roof.
Dyoung is offline   Reply With Quote
Old 03-23-2010, 02:50 PM   #5
A good exterminator would have been 100% sure that this was not caused by termites. Those perfectly round exit holes were created by a beetle. Most likely a powderpost beetle but impossible to say for sure without a photo.
BugsBugMe is offline   Reply With Quote
How do I replace termite damaged top plate under trusses on a load bearing wall? durangorob Carpentry 7 07-25-2011 08:45 AM
Termite exetermination tenting house. gante Pest Control 11 07-18-2010 11:44 AM
How do you determine the extent of termite damage?? 4just1don Pest Control 1 05-25-2009 10:34 PM
Need some advice on buying home termite & water damage. Mr Heshup General Discussion 1 03-29-2009 04:06 PM
How to Fix Termite Damage iammos Building & Construction 12 07-21-2008 04:58 AM
