Is This Termite Damage? - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 04-06-2011, 10:37 AM   #1
Is this Termite Damage?
So I started gutting my front porch yesterday as part of renovation work and behind the old sheathing I found what looks like insect damage. Pieces of wood had either fallen off the studs or I could easily pull away. Attached are pictures of what the pieces that broke away looked like and the remaining stud.
There was also small piles of dark brown material nearby.
Is this termite damage? Should I just replace all the damaged studs?
pankaek is offline   Reply With Quote
Old 04-07-2011, 05:07 PM   #2
pest control operator
It "looks" like wood-boring beetle evidence. If so, it is made by the larval stage, which turns into an adult beetle and chews its way out. Did you find oval shaped holes on exterior of wood?
The brown material-is it wood dust or mud? Wet it-if it smears it is mud, if not it is fine wood frass. Wood frass indicates wood boring beetles/larva.
Subterranean termites bring mud into the wood. They don't make wood dust or frass. Let us know what you find.
PAbugman is offline   Reply With Quote
Old 04-08-2011, 10:44 AM   #3
Tried the wet and smear test - it kind of smears a bit but feels almost gritty or sandy texture. I have the professional exterminators coming by today to examine the damage so I'll post what they find later.
Old 04-08-2011, 10:49 AM   #4
get 2 opinions
The older I get the better I was
Old 04-08-2011, 01:26 PM   #5
well it's not termite damage according to the exterminators. The entry holes are 1/32 to 1/16 in diameter and are Round. I'll get another exterminator who specialises in wood boring beetles to take a look next week and see what they say.
Does this look like termite damage? Rachie7987 Pest Control 1 11-20-2010 08:01 AM
Is this termite damage? snosurfa7 Pest Control 4 03-23-2010 01:50 PM
How to determine age of ... TERMITE DAMAGE ????......new or old??? Dyoung Pest Control 9 02-26-2010 08:32 PM
Need some advice on buying home termite & water damage. Mr Heshup General DIY Discussions 1 03-29-2009 03:06 PM
How to Fix Termite Damage iammos Building & Construction 12 07-21-2008 03:58 AM
