Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 03-02-2010, 09:49 PM   #1
stubborn flea problem
I am treating an apartment with a heavy flea infestation (2 cats, 2 years). It is so bad I bag everything I wear after I am done.
The product being used is 'enforcer flea spray for homes' with .01% nylar and .25% permethrine.
I thoroughly sprayed the empty apartment once. When I came back to do some work I was again assaulted by fleas, so I sprayed the entire place again.
Why didn't the permethrine kill them off the first time? And how many treatments will I need? I know there are new fleas emerging from coccoons, but are there that many, or should I get a better flea product, maybe precor?
darsunt is offline   Reply With Quote
Old 03-02-2010, 11:47 PM   #2
Have you tried the bug bombs in an aerosol can?
Barb
gma2rjc is online now   Reply With Quote
Old 03-03-2010, 07:09 AM   #3
IGR= Insect Growth Regulator is key. Also you will need to vacuum, but you will have to wait a little time before doing so. Most brands have residual base, meaning they work longer on the pesky little critters. Precor is a good start.
Good Luck
mark942 is offline   Reply With Quote
Old 03-03-2010, 09:39 AM   #4
sdsester's Avatar
Before you waste a lot more money on worthless products availed you as a consumer, call in a pro exterminator who has the real stuff and be done with this. It will be a lot cheaper in the long run.
sdsester is offline   Reply With Quote
Old 03-03-2010, 10:31 AM   #5
The pros know more than I do, but even they can't get the fleas in the coccoon.
Old 03-03-2010, 10:50 AM   #6
Xtreme DIY'r
Actually there is stuff that will kill them as they emerge, larvae stage
Their life cycle can be several months (2-20 weeks)...so that is one problem
Summer cycle is faster @ 2 weeks
One site indicates that steam cleaning kills the eggs
Old 03-03-2010, 03:11 PM   #7
Vacumn & steam..... repeat every 5 days til they are gone... don't mis a crack or hiding place. (info the chem co's don't want you to know...it's big biz)
Chems for adult and larve stage...they at least make you feel proactive
in the battle.
Big Bob is offline   Reply With Quote
Problem with fan coil unit/hydronic system. flood1911 HVAC 2 09-05-2008 05:57 PM
2 switches , one light problem pepperthecat Electrical 2 07-08-2008 04:57 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
