Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 11-21-2010, 10:14 AM   #1
squirrels in the attic -- strobe
Hello All
I've found products for rodent control using strobe lights:
http://www.evictorproducts.com/
http://www.rodentstrobe.com/
...I'm not ready to invest that much money into a solution that I'm not sold on.
Has anyone used these products? Has anyone used alternatives (thinking cheaper strobe light from radio shack)
~Todd
tsimons78 is offline   Reply With Quote
Old 11-21-2010, 10:46 AM   #2
Chicago, IL
Michael Thomas's Avatar
How about experimenting with one of the inexpensive battery powered Search and Rescue strobes first, for example:
http://www.aircraftspruce.com/catalo...tmanstrobe.php
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
Old 11-22-2010, 07:28 AM   #3
pest control operator
Interesting idea. Don't know if it will work or not, but be aware that a flashing strobe light in the attic will probably show thru vents, exhaust fans, soffit/gable cracks and crevices, etc. You will attract attention from neighbors and possibly 1st responders,and (exorcism priests?!).
PAbugman is offline   Reply With Quote
Old 11-22-2010, 08:41 AM   #4
...a good way to see if you have nosey neighbors!
This is actually an enclosed space above an addition. This is a new home, I haven't found an access panel, I'll probably have to cut one.
Old 11-22-2010, 08:43 AM   #5
Wish it lasted longer than 3~7 hours. ...maybe I can get creative with a power pack from radioshack and a soldering iron.
Thanks!
Raccoons in the attic electricpete Pest Control 17 05-12-2011 05:02 AM
Attic fan options P550 Roofing 1 08-22-2010 01:47 PM
Attic fan options. P550 Electrical 6 08-22-2010 01:30 PM
squirrels in the attic jkrodger Pest Control 41 12-17-2009 01:39 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
