Spot Treating Termites ?
It also depends on what type of termites you have. In my area, spot treatment is effective if you don't have a bigger problem.
My house was tented in 2000....since then I have found only one spot where there was active termites (their left overs looks like saw dust)...I soaked the spot with a diluted mixture of Cyfluthrin...vac'd up the tail tail signs....check back a few weeks later....nothing.
Now, like Joe said, they could have moved on to another spot....but then again, I soaked everything in the area.
But I'm also the type that is constantly in the attic looking for evidence....Most the attic is floored so it's easy to spot....
With that said.....as soon as the outside is wrapped....we are going to tent the whole structure before we drywall the addition. We had a pretty good termite swarm last year....I think I got any critters that were trying to find a new home (I sprayed down the whole section of exposed framing)....but I'm not taking chances....
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
