Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 07-12-2007, 05:12 PM   #1
Question
Something eating my deck....
I just moved into an apartment about two months ago. When I moved in I talked to my landlord about a couple of boards on my deck being soft..kinda squishy when I stepped on them. I noticed a few carpenter ants scurrying around and called again. Now the carpenter ants are gone and there are weird little centipede creatures that have taken over their home in the wood of my deck. The landlord is coming to replace the deck but the evil little critters are now inside my apartment too. Everything I've read says you can not kill a centipede. Any tips?
JDmommy is offline   Reply With Quote
Old 07-12-2007, 07:40 PM   #2
Is it a centipede or millipede? you can tell by the number of legs in each segment (millipedes have 2 pairs, centipedes have 1)... centipedes are predatory were as millipedes eat vegetation, hence possibly your deck... Keep things dry and there are many chemical control products/pesticides...
slakker is offline   Reply With Quote
Old 07-15-2007, 04:52 PM   #3
Sounds more like millipedes which feed on decaying organic matter such as rotting deck boards
Any bug can be killed (cept lubbers)some just require more time than others so bugmen say that they can't be killed because they are paid by commission not by the hour
A wettable powder or CS formulated pesticides applied around the entry points and known harborage areas will do the trick, it may take two or three applications and there goes that whole commission thing again
ocoee is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
What is chewing up my second floor deck? onitasanders@yahoo.com General Discussion 10 08-10-2007 11:19 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
deck walls maintenance Building & Construction 6 04-03-2005 11:37 PM
