Repairing Termite Damage - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 04-18-2011, 09:32 PM   #1
repairing termite damage
I'm remodeling my bathroom and came across some obvious termite damage. Pest control has been called and appointments are made.
This whole bathroom was an add-on to the original house some time after initial build (yr?). The damage is in the two corner studs of the bath/shower which happen to be the exterior wall with damage also done a single plank of horizontal sheathing.
Finally my questions : do the studs and sheathing have to come out OR can I apply some kind of filler to the wood?
Also how does wood filler work in these cases? Does it expand and penetrate? Can I use "Great Stuff" /Hilti expanding foam to accomplish this? Would that make the wood structurally safe? Does an anti-pest product like that already exist?
Thanks for any help you can provide.
Pictures and/or video coming soon.
James
NJoytheRide is offline   Reply With Quote
Old 04-19-2011, 05:50 PM   #2
Too Short? Cut it Again!
Little devils.
There are expoxy products that can re-store the most damaged of rotten or insect eaten wood to stronger than normal but your local inspector will not buy into them for structural members. You should should see what the exterminator says first. Then sister the members you need to replace with new members, fit new structure and be done. Usually with termite damage, but not always, what you see is but a minor portion of the problem though.
Going to cost you a few schillings from what you planned to toss to the Royal Wedding but here is the right way to do it.
You do need to find where that moisture is coming from and resolve that. Termites love warm moist wood more than the whole logs they eat in the environment.
Old 04-21-2011, 11:12 AM   #3
Ok here's a video of the damage. You'll see that the bathroom is an add-on to the back of the house so if I need to remove the exterior siding to repair damaged wood, I won't be taking off a lot.
Please check it out and let me know what you think!
Thank you
James
http://www.youtube.com/watch?v=VMWZl...e_gdata_player
Does this look like termite damage? Rachie7987 Pest Control 1 11-20-2010 09:01 AM
How to determine age of ... TERMITE DAMAGE ????......new or old??? Dyoung Pest Control 9 02-26-2010 09:32 PM
How do you determine the extent of termite damage?? 4just1don Pest Control 1 05-25-2009 10:34 PM
Need some advice on buying home termite & water damage. Mr Heshup General DIY Discussions 1 03-29-2009 04:06 PM
How to Fix Termite Damage iammos Building & Construction 12 07-21-2008 04:58 AM
