Removing Squirrels - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 12-02-2013, 09:06 AM   #1
Rewards Points: 3,130
Removing Squirrels
There is a void space in my attic where a couple of squirrels have taken up residence. The space is inaccessible except for a small opening where they are getting in. I can easily block the opening, but am concerned I may trap one of the critters inside when I do. What can I do to reliably lure them out? I know the odds are good they'll be out and about in the afternoon, but would prefer to be a bit more certain.
The Following User Says Thank You to md2lgyk For This Useful Post:
noquacks (12-02-2013)
Old 12-02-2013, 10:12 AM   #2
Rewards Points: 2,040
Havaheart makes small traps. If you want to try a catch and release. Or, do you mean the space is inaccessible to you?
Home Depot sells the traps.
Startingover is online now   Reply With Quote
Old 12-02-2013, 06:55 PM   #3
Rewards Points: 1,062
Pour 10% industrial strength (Ace Hardware) in a shallow quart container, place it inside up there in the attic (hold your nose), and watch them scram out so dang fast.........leave it there for at least 2 days.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 12-02-2013, 07:02 PM   #4
Firecrackers
johnapotamus is offline   Reply With Quote
The Following User Says Thank You to johnapotamus For This Useful Post:
TheEplumber (12-02-2013)
Old 12-02-2013, 07:09 PM   #5
Industrial strength what??
The Following 2 Users Say Thank You to md2lgyk For This Useful Post:
raylo32 (12-02-2013), roofermann (12-02-2013)
Old 12-02-2013, 07:15 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 358
Here's an entertaining read- might be of some value to you.
It's a different critter- but who knows----- I may have a Raccoon in my fireplace chimney
Old 12-02-2013, 08:16 PM   #7
bbo
one way door ( but not with babies involved)
bbo is offline   Reply With Quote
Old 12-03-2013, 12:39 AM   #8
Rewards Points: 126
It's always better to first eliminate the method they are using to get on the roof. That probably means trees too close to the house, or gutter downspouts they can climb up. Then patch the hole, otherwise they will just chew a new hole. They have good teeth and all the time in the world.
ChuckF. is offline   Reply With Quote
Old 12-05-2013, 08:46 AM   #9
Eliminating the access method would be difficult. I have a log house, and they simply climb up the side of it (I've watched them do it). I could probably use some sort of guard like what is used on birdhouse poles, but that would be ugly.
An earlier poster mentioned some "industrial strength" chemical to repel them, but neglected to mention what it is. Do you have any idea? Ammonia, perhaps?
Old 12-05-2013, 12:45 PM   #10
Rewards Points: 456
After you've determined how to block access, shoot the entrance with a potassium bicarbonate fire extinguisher. They will be fine after coming out for a breath of fresh air and it's doubtful there are young in there at this time of year but will possibly be in late winter.
Old 12-05-2013, 06:03 PM   #11
oops, sorry- 10% ammonia. thinking faster than I can type.......
Old 06-29-2016, 02:09 PM   #12
Rewards Points: 128
Re: Removing Squirrels
There are extractors (not sure of the actual name). This is placed on the entry point and allow the squirrel to leave but not re-enter (made for going out only). Since squirrels go out in the A.M. in search of food, the contraption should be left on for about 4 days just to make sure the rodent is out. Then galvanized steel mesh is put over the entry point as squirrels can't chew through this (as of now!!). Good Luck
Jacke is offline   Reply With Quote
Removing wall mount sink connector OldHomeJen Plumbing 6 11-27-2013 09:45 AM
Removing tile; electric tile stripper or rotary hammer? mackaz Flooring 0 07-21-2011 07:22 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 11:49 AM
Help removing baseboards without damaging sheetrock Lighthearted Painting 3 04-05-2009 06:52 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 10:28 AM
