Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 01-17-2009, 02:00 PM   #1
Rats! Tunneling into my dirt crawlspace!
I have a rat issue. We have trapped all or most of them, sealed up everything outside of our OLD house. It has a stone foundation with a dirt floor. I have found a tunnel in the dirt, stuffed it with insulation to see if it was active, few days later checked again and the insulation had been dug out. The crawlspace is very tight...lower than 12 inches. In the past I had worked in the building trades and we would often use a vapor barrier and gravel in a crawlspace. I have also heard of people using sand. Would these be effective in blocking out rodents? Concrete would be very hard to use for a rat slab due to the tightness....gravel or sand won't be any fun either... Some of the dirt is dug out so that it is on different levels and I have dirt "walls" so to speak. I thought I might use some wire mesh and mortar to cover them. Any thoughts are apprecitated. Also what do I do with this hole...some say leave it alone until the rats are definitely all gone. I cannot find the other end of it on the outside.
Thanks in advance!
PastorErik is offline   Reply With Quote
Old 01-17-2009, 02:20 PM   #2
Master General ReEngineer
Ayuh,...
Leave D-con bait traps around,...
As long as the bait traps have bait in them,... They're Working... If they're Empty, refill them...
And,.. You won't have a Rat Problem again...
Old 01-17-2009, 02:24 PM   #3
Thanks for the tip. I won't use poison. They carry it all over and store it. Plus I don't want rotting dead rats randomly laying around and in my walls, etc. causing bad odors, etc. I am using snap traps, I set them out unbaited for a few days, then rebaited and set them and caught 3. Its been 2 weeks or so and I have not caught another since...We do still hear at least one in the ceiling occasionally.
Old 02-01-2009, 07:01 PM   #4
Jer
There is a product on the market that you may have seen TV ads for.
It is a device that you plug into an ordinary wall socket that sends some sort of electrical signaling through your house wiring and is supposed to repel pests.
Havent tried it but I asked an electrician friend of mine and he said that he had heard of the device and that theoretically it could work.
Jer is offline   Reply With Quote
Old 02-12-2009, 06:16 PM   #5
Those electronic things dont work..They were installed in my house when I moved in. Caught several mice.
Total waste of $.
Wish they worked..Thatd be conveneint..
Tommy2 is offline   Reply With Quote
Old 05-05-2009, 10:03 PM   #6
My husband and I have been having problems with rats and mice as well. We use the glue traps because it doesn't kill them and we don't have to worry about poison in our house. They really work but I don't feel like we are getting them all. We have tried the plug ins...they don't work. But now we are finding piles of dirt in our garage off in one corner by where our dryer vent goes outside. Either the mice or rats have been bringing in the dirt...but how? We live in a fairly new house and I don't want it destroyed by the mice.....HELP!!
shylad5 is offline   Reply With Quote
Old 05-06-2009, 01:27 AM   #7
shylad,
make double darn sure that that dirt your seeing isnt a result of termites. They love to bring mud tunnels inside where they make runs. If it is loose soil,whats under it,the hole?? Dryer vents are notorious for allowing rats and mice inside. FIRST advice is use ONLY solid metal pipe,NOT flex plastic pipe. Once mice or rats are inside,they quickly chew thru it and they are inside your house. Secondly,the metal flapper kind is the worst for letting them in. A scrap of lint keeps door open a fraction and they can scurry in. The kind that rises 'up' when air is blowing out helps keep them out. gravity drops it back down. occasionally put your hand in there and wipe out lint rems.
If you have alot of mice,,,a revolving tin trap that repeats many times helps. Put popcorn in it for bait,cheese etc. the wind up like an old time alarm clock
4just1don is offline   Reply With Quote
Old 05-06-2009, 10:27 AM   #8
Long-Time DIYer
Mike Swearingen's Avatar
I've lived on the waterfront of a double-cropped farm for more than 32 years. I have a dirt crawlspace, and get lots of mice and rats when the weather starts to turn cool. They tunnel in under the foundation.
It is "tight" under my house (no pets can get in) and I keep fresh D-Con out under there from early Fall through Spring. 99% of those zapped by the D-Con stay under the house.
Very few (1 to 4 a year) get up into the house itself because they haven't eaten D-Con. I used to use regular flat snap traps inside the house (utility room and kitchen is the only places that I've ever seen them), but I switched to the glue and the round snap traps. The round traps seem to work better than the glue type, but both work. I use cheese or peanut butter for bait on both.
No problems.
Mike
Mike Swearingen is offline   Reply With Quote
More On This Topic
Hi! I'm Mark Sullivan for Expert Village and today, we are going to learn how to build a barbecue pit. So we are going to use just a bed of recycled pea gravel to level our blocks, our concrete blocks. Now you can use sand for this, you can use just dirt... Read More »
I am Dr. T. K. Roy, speaking on behalf of Expert Village. Protecting our birds from predators, as I have already explained, there are different kinds. See, from the, from the rats, et cetera, which come from under the ground, you know. So what do they do... Read More »
Learn how much substrata (gravel or sand) to put in a fish tank and how to maintain an aquarium in this free video on caring for fish and fish tanks. Read More »
There are a variety of plant choices for a garden pond. Floating plants are simply placed on the surface of the water; however, emergent and submersed plants should be placed in containers. Establishing plants in a pond requires special gardening know... Read More »
All right once you have turned over all of the sod in your garden, what you would want to do is come in and break off most of this dirt. Some people I know will put this back in the bottom. But I don't like to because I am afraid I am going to just... Read More »
Protecting siding base in dirt Bambu Building & Construction 11 08-11-2008 10:19 PM
Is there a proper fill dirt for grading? Sonabi Landscaping & Lawn Care 2 04-19-2008 12:23 AM
Reinforcing dirt walls in crawlspace Fix-It Chick Building & Construction 8 01-13-2008 12:57 PM
musty crawlspace svmaine Building & Construction 2 09-03-2007 04:53 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 08:49 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
