Rats In The Attic. Help. - Pest Control - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 08-17-2011, 07:37 AM   #16
Rewards Points: 252
Squirrels get into my basement occasionally, so I have a live trap with an apple, or sometimes peanut butter. If you are feeling industrious you can dump them on the other side of the city, but I just give them swimming lessons.
shazapple is offline   Reply With Quote
Old 08-20-2011, 04:15 PM   #17
Rewards Points: 530
Originally Posted by boman47k View Post
If you hear them scurrying around in the attic, I'd bet on squirrels. I don't think rats scurry like squirrels.
If it is squirrels, I doubt you will catch any in the attic with any kind of trap. When I had my squirrel problem, I read an article by some guy that stated they will not be trapped inside the attic.
I had two live traps, a gopher trap, and a leg trap in the attic for a good while with peanut butter and seeds. They were ignored completely. All mine were caught in the yard or leaving the attic in a matter of several days.
squirrel nest
Billy the Exterminator may have just disproved the atement about squirrels not being caught inside the building. He supposedly trappede one in a lady's attic.
Old 08-20-2011, 11:31 PM   #18
Rewards Points: 590
I now have 24/7 surveillance going on in my attic now. I borrowed my bro-in-law's deer cam and have set it up facing a piece of cardboard baited with peanut butter stuck with macademia nuts.
Let's see what this turns up.
Hopefully NOTHING.
noone is offline   Reply With Quote
The Following User Says Thank You to noone For This Useful Post:
Leah Frances (08-20-2011)
Old 08-21-2011, 10:17 AM   #19
Rewards Points: 590
Deer cam, night 1. Looks pretty big. Rat or big mouse?
Old 08-22-2011, 02:44 PM   #20
pest control operator
Norway rat. Kill them in traps, with poison, whatever you got to do.
PAbugman is offline   Reply With Quote
Old 08-22-2011, 02:47 PM   #21
fabrk8r
fabrk8r's Avatar
Puts some snakes up there.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-22-2011, 03:20 PM   #22
Rewards Points: 590
I found at least one opening where I think they are getting in. I closed it up yesterday afternoon. Put some snap traps out using the same bait I used when these pics were snapped and caught nothing last night. Baited them with peanut butter with a macadamia nut on top. Nothing. Rat(s) didn't go near it. Is it possible that it was already out during the day and now can't get in? My dad said to bait with raw bacon which I will try tonight.
Old 08-22-2011, 03:32 PM   #23
He may have gotten out, but rats are neophobic; that means fear of something new. If they have a food source they may avoid yours for a while. The bacon idea is good-Iíve suggested that to others. Macadamia lure was marketed heavily to us as a sure-fire lure for rats and mice. The hype and marketing has slowed down a lot, probably not as good as they wanted it to be. I would tie the bacon on to the trigger with dental floss or thread. That will require them to pull on it; SNAP! Good Luck.
Old 08-23-2011, 08:26 AM   #24
Rewards Points: 590
He may have gotten out, but rats are neophobic; that means fear of something new. If they have a food source they may avoid yours for a while. The bacon idea is good-I’ve suggested that to others. Macadamia lure was marketed heavily to us as a sure-fire lure for rats and mice. The hype and marketing has slowed down a lot, probably not as good as they wanted it to be. I would tie the bacon on to the trigger with dental floss or thread. That will require them to pull on it; SNAP! Good Luck.
Baited two snap traps with bacon tied to the trigger with dental floss. Nothing. No appearance by the rat(s), the deer cam confirmed it.
Timeline so far:
1. 8/21, 5:00am, deer cam takes 2 pictures of rat near peanut butter topped with macademia nuts on cardboard (no traps), as shown in above post.
2. 8/21 - 5:00pm, I close up a hole on the outside of the house where there was obvious entry. Set two snap traps baited with peanut butter and macademia nuts.
3. 8/22 - 7:00am, check the traps, bait untouched, deer cam confirms no activity. At 7:00pm, I rebait the traps with tied bacon.
4. 8/23 - 7:00am, check the traps, bait untouched, deer cam confirms no activity.
How many more days do I do this before I declare 'success'?
Do I need to rebait with fresh bacon every day, or does that matter?
P.S. - the only reason I used macademia nuts was because we happened to have a bag of them that someone gave us.
Old 08-23-2011, 10:59 AM   #25
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
No expert, but from what I've read placement of the traps can make a difference. Rats tend to follow the walls rather than walk across the middle of an area. Place your traps along the wall where they are most likely to travel.
Old 08-23-2011, 01:13 PM   #26
Rewards Points: 3,130
Sounds like bats to me too. I had issues with them in my attic. A .410 shotgun with bird shot did the trick.
Old 08-23-2011, 03:01 PM   #27
Rewards Points: 590
Uhhh, it's not bats. See post #19
Old 08-23-2011, 03:05 PM   #28
noone: It all sounds good but itís hard to put a time frame onthese guys. We are humans and have to be careful about projecting our logical thinking onto their behavior. blondsense is right about rats traveling along walls-they feel with their whiskers as they run. However, hunger and food can override that behavior. Youíve seen and heard nothing-another day or so and Iíd relax, but stay alert. If the bacon isnít rancid, leave it on.
Old 08-23-2011, 03:10 PM   #29
Rewards Points: 590
I put the traps in the exact same place as I had left the 'free' bait the night when I caught them with deer cam pics.
I tend to agree that if it/they are now trapped inside, they will be seeking out food with a vengeance and won't be so picky. The fact that the deer cam has spotted 0 activity leads me to think that he has left the premise, but I will try for 4 more nights just to be sure. I don't want to end up with a dead starved rat in my attic.
Old 08-24-2011, 06:24 PM   #30
Rewards Points: 590
Foiled again by this pesky rat!! I didn't check the deer cam until tonight. Bacon bait has been on the snap traps for two days now. When I checked it last night, one of the traps had been tripped and tonight as well. One of the water heaters is about 5 feet away, so I thought that it expanding and contracting (it makes noises when it heats up) might have possibly caused it, but it looks like it is this rat causing it. It's almost as if he smells a trap. I will rebait with some fresh bacon and try again. The trap I am using is a Victor rat trip with the metal trigger. Do I need to buy the one with the plastic pedal? Seems like this guy may be pressing the side of the trap to test it first before going for the gusto! Smart little f'er.
Bro-in-law says to use glue traps......
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 04:17 PM
Attic fan options P550 Roofing/Siding 1 08-22-2010 12:47 PM
rats is my crawl space and in my attic this old house Pest Control 5 06-02-2007 05:48 PM
