Rat feces and urine in insulation
after some demolition, I discovered the insulation was covered in rat fecies and urine. I was going to keep it, but now, i think I would I have to replace it.
What is the best way to clean this up? This is fairly new looking pink fiberglass insulation, so no worries with asbestos. I'm just worried about diseases carried in rat droppings. This is insulation in the joist space between 1st and 2nd floor. I don't know how rats could have gotten in there in the first place, it is all sealed up. |
IMO I would replace only what you have found so far otherwise once you seal it up it will always be there physically and mentally. Take care of the infestation and look for any possible entry points around the house. During any infestation you are going to have fece/urine that you might not want to know about.....eliminate the pest and seal all entry points. My vistors found an entry via crumbling caulk around HVAC pipes for example.
Also wasn't sure if there were special requirements for disposal since its something that can carry diseases. |
Youre more likely to catch something from the next human you encounter at the grocery store.........or on your next flight to London........ |
"Hantavirus Pulmonary Syndrome (HPS): Hantavirus pulmonary syndrome (HPS) is a deadly disease transmitted by infected rodents through urine, droppings, or saliva. Humans can contract the disease when they breathe in aerosolized virus. HPS was first recognized in 1993 and has since been identified throughout the United States. Although rare, HPS is potentially deadly. Rodent control in and around the home remains the primary strategy for preventing hantavirus infection." |
Gloves, and a well fitting N-95 mask. I don't know where the other poster got the idea that you can't get diseases from rat leavings. Get rid of all of it.
Learn about respirators and which model for what contaminant, etc. Learn how hantavirus is ingested: airborne, orally, thru skin penetrations? I don't the answer. Can't argue with being safe, you only get one chance to be safe. If you use a shop vac, make sure that you're not making your environment worse with the exhaust.
That said, I haven't heard of a hanatavirus case for years. No one that I know, including myself, even thinks or talks about it. I've been in pest control about 30 years, more or less, in a wide variety of situations. Involved in trade association, know and talk to many fellow operators. I'm more concerned about working near sinks, toilets, etc. I keep and use a lot of hand sanitizer in my truck. Doorknobs cause more contamination than any other single item. Lyme disease, West Nile, and staph infections are very real threats to us. Take reasonable precautions and monitor yourself for symptoms afterwards. |
I have run into this problem many times. Remove and replace insulation. But before replacing insulation. Let air dry for a couple of days. Then I would prime all effected areas in a oil based paint to encapsulate the urine smell. Be sure to remove and clean all areas before painting. My 02 worth.
Good Luck :thumbsup: |
I never thought to paint the area. There are some stud bays of finished walls that were painted in other parts of the house. I always wondered what that was for. |
| All times are GMT -4. The time now is 02:45 AM. |
