Pressure Sprayers: Multi-chem Use? - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 05-11-2011, 04:24 PM   #1
Rewards Points: 150
Pressure Sprayers: Multi-chem use?
Can I buy one sprayer for all pest control chemicals (rinsing between chemical types) or is that problematic? Right now my usage would be Termidor and Timbor, but I'll likely be obtaining other pesticides in the future, i.e., roaches, silverfish, etc.
Thanks,
Mark
rightit is offline   Reply With Quote
Old 05-11-2011, 04:30 PM   #2
Learning by Doing
Leah Frances's Avatar
I don't like to mix chemical use in one sprayer. They are cheap if you buy them on sale. Label. Guess this isn't very helpful. But I often use mine for washing walls and I don't like the idea of having pesticides in my house.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following User Says Thank You to Leah Frances For This Useful Post:
rightit (05-11-2011)
Old 05-11-2011, 04:39 PM   #3
Rewards Points: 150
Hi Leah,
Thanks for your response. I would reserve this sprayer only for pesticide use, and only for my home and shop (same location). If I need a sprayer for any purpose other than pest control chemicals, I'll buy another one. A decent 'cheap' sprayer around these parts runs $20 or more (and that's just for a 1 gallon...I'd prefer 2 gallon). I anticipate that I might use 4 (give or take) different pesticides no more than once a year, so that would be at least $80 +tax for pressure sprayers, not to mention the space to store them. I will if necessary, but I'd prefer not to.
Mark
Old 05-11-2011, 06:42 PM   #4
pest control operator
No problem using one sprayer for all. You could even use Round-up in it, as it leaves no residual. Before you use Termidor, clean it out more thoroughly as Termidor is non-repellent, which contributes greatly to its effectiveness. You don't want the residue of a repellent, which most are, to work against you when using Termidor.
We have a sprayer designated just for Termidor, and one for all others. We use a lot of Termidor though; clean it out with warm water and some dish soap prior to using Termidor.
PAbugman is offline   Reply With Quote
The Following User Says Thank You to PAbugman For This Useful Post:
Old 05-11-2011, 07:46 PM   #5
Rewards Points: 150
Thanks (again ) PAbugman. I don't mind buying one additional sprayer (and I'd rather not take chances on reducing the effectiveness of the Termidor), but 3 or 4 is a bit much.
Mark
Old 05-11-2011, 08:01 PM   #6
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
To ensure it's well rinsed I always do a full spray of just water after I'm done. So I'll rinse it, then fill it, then just spray all the water out. This will force any residue out, at least that's my theory, I have not scientifically proven it. :P
The Following User Says Thank You to Red Squirrel For This Useful Post:
rightit (05-14-2011)
Old 05-11-2011, 08:05 PM   #7
Learning by Doing
Mark
Shucks. After 10 years of owning sprayers I've got 5 or 6 now. Including two mini-ones still in the packaging. I pick 'em up at Wal-Mart for cheap at the end of the gardening season.
And, well, storage isn't a problem for me
Good luck. Glad some other folks had some useful advice.
Old 05-14-2011, 04:52 PM   #8
Rewards Points: 150
Thanks, Red Squirrel. In fact, I did just that (even though I bought 2 separate sprayers & labeled them, no point in letting residual chemical sit in the sprayer.
Leah: Thanks for the tip. I actually found some for $10 each.
Mark
Boiler pressure troubles jduffett HVAC 2 12-12-2010 07:15 AM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
Older air compressor wiring help lash-1295 Electrical 91 12-23-2009 12:46 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 09:50 PM
