Pre-treat Or Not To Pre-treat? Fire Ants - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 12-21-2013, 03:42 PM   #1
Pre-treat or not to pre-treat? Fire Ants
Greetings,
I'm in the process of purchasing just over a 1/4 acre of land and see that it's infested with fire ants. Apparently this is the one thing I didn't count on when moving to SC. My question is, should I pre-treat the property before the excavation begins? It's my understanding that using bait for fire ants is best done when not disturbing the mounds, ergo I should do some control prior to excavation.
Thoughts?
Iguana Man is offline   Reply With Quote
Old 12-23-2013, 10:33 AM   #2
Rewards Points: 320
Just a suggestion, I would first go to your local county agricultural department or professional exterminator for your area and ask them what's the best way to get rid of them. They may know more about your specific location and be able to help. Just a thought.
If no help there, then I would excavate, wait a couple weeks, see where they pop up afterwards, then treat the mound. As you probably know, the queen must be killed to destroy the nest. I'm sure you'll kill a few queens during the excavation process. However, you'll never get rid of all of them anyway. It's an ongoing process that you will have to stay on top of. Be vigilant.
Stay tuned, there are a couple of professional exterminators that are regulars on this forum, maybe they will chime in and give you some more advice. Thanks.
jmon is offline   Reply With Quote
Old 12-23-2013, 12:08 PM   #3
K&B Designer
Live_Oak's Avatar
You never "get rid of" fire ants. You only reach a sort of detente with them where they aren't in places that you traffic a lot. You learn to live with spotting mounds as a regular maintenance activity, and teach vigilance for them to all family members.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
jmon (12-23-2013)
Old 12-26-2013, 12:06 PM   #4
Thanks for the replies. I should have mentioned that the excavation will be for a manufactured home with brick underpinning. In other words, they'll basically be scratching the surface of the ground and not killing any queens which I assume are going to be deep underground.
The Following User Says Thank You to Iguana Man For This Useful Post:
jmon (12-26-2013)
Stripping off old paint blwegrzyn Painting 71 11-28-2013 12:43 AM
Fire ants streetneons Pest Control 11 06-29-2013 07:45 PM
Red Fire Ants in MA calitriv Pest Control 3 07-15-2012 06:24 PM
Florida fire ants Startingover Landscaping & Lawn Care 2 04-24-2012 01:19 PM
Fire ants coming into house through pipes in foundation -- need advice samalex Pest Control 15 03-22-2011 01:35 PM
