Powderdust Beetle? Mount Of Small Particles On Bamboo Floors. - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 06-13-2014, 10:24 AM   #1
Rewards Points: 81
Powderdust beetle? Mount of small particles on bamboo floors.
Hey guys!
We got back from a vacation and I noticed a mount of small particles (1 inch in diameter) on my bamboo floors. Upon removing the particles, I discovered a small hole in bamboo flooring. I did a little research online and I think it's a powderdust beetle, but may be mistaken.
Should I call pest control, or is there a chemical I could use myself?
Thanks!!!
edavt04 is offline   Reply With Quote
Old 06-13-2014, 03:55 PM   #2
Rewards Points: 264
Please see a few posts down: I think something is eating my nightstand
nanuk is offline   Reply With Quote
Old 06-13-2014, 05:01 PM   #3
DIY staff
Rewards Points: 7,174
powder post beetle is the name---
Old 06-14-2014, 07:59 AM   #4
Rewards Points: 472
Originally Posted by edavt04 View Post
Hey guys!
Thanks!!!
was this just put in ?? if so have the company remove all , if beetle's they will eat the floor up, if that is what they are, did you have some new item's you bought some where and set on the floor ? call pest control now
del schisler is offline   Reply With Quote
The Following User Says Thank You to del schisler For This Useful Post:
oh'mike (06-14-2014)
Old 06-14-2014, 09:29 PM   #5
Rewards Points: 264
Even dry bamboo contains high amount of starch, which is the food source of the powderpost beetle. Ask any panda.
If you can't make warranty claims, go with a pest control company, as del schisler suggested.
If you cannot afford that, watch carefully and treat each hole as they appear. The beetles will emerge from the top as the subfloor is immune to the boring adult. The adult cannot lay eggs in varnished wood but will use the emerging hole again if conditions are right.
Maybe the infestation is localized. And certainly do not panic. Those are not an army of carpenter ants. Everything proceeds at a very slow pace.
Old 10-04-2014, 12:40 AM   #6
Rewards Points: 238
if trying to DYI remember that anything you apply to the floor won't work where there is also finishing, you have to have it sanded down to untreated wood to treat it.
Gustavas is offline   Reply With Quote
Tags
bamboo , infestation , powderdust beetle
Getting ready to lay bamboo floors urbaneve Flooring 3 04-04-2013 09:18 AM
Bamboo floors, cracking sounds from staples, need fix! JasonU27 Flooring 0 12-18-2012 02:54 PM
To use, or not to use Bamboo... dmcandy Flooring 10 08-23-2012 01:19 PM
bamboo floors pwarshaw Flooring 2 08-10-2011 09:40 AM
Particles showing through the polyurethane over my newly-sanded hardwood floors proofer Flooring 3 12-10-2008 09:42 AM
