Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 07-22-2014, 06:37 PM   #1
Rewards Points: 8
Share |
Powder post beetle??
Just noticed this pile of sawdust in my basement. I know it is less than 7 months old because it was partially on top of some leather furniture I put there 7 months ago.
I haven't noticed any other similar piles of dust. This is by an exterior wall. The 2x lumber in the pic goes out to a deck and that particular joist is pretty rotten after it goes outside the house.
I'm pretty sure this is from powder post beetles. I'm basing this on pictures I've seen online. Supposedly they are common in the Seattle area.
It seems like a lot of dust in one area. Does this look like a bad infestation, or have I caught this early? Is this a job for a pro, or can I buy some stuff at the store and treat it myself?
How quickly will they spread?
On a side note, I had a heat pump installed a couple months ago and the humidity in the basement has dropped significantly. I've read that wood boring insects prefer high humidity.
Powder post beetle??-image-3548466125.jpg   Powder post beetle??-image-2841376775.jpg
dftc is offline   Reply With Quote
Old 07-22-2014, 07:59 PM   #2
Rewards Points: 192
If it's powder post beetles there will be hundreds holes the size of an ice pick, carpenter bees will make a hole about 3/8" perfectly round.
Both can be treated with a product called Bora Care.
Google it.
Old 07-23-2014, 01:30 AM   #3
Rewards Points: 8
Thanks,
I don't see any holes at all, although it appears that they might be between the boards.
I'll look into the product you mentioned.
Old 07-23-2014, 07:56 AM   #4
Rewards Points: 192
Looks like way to much saw dust for powder post beetles.
With that much damage I'd be contacting an exterminator and looking into getting rid of that rotten wood.
Old 07-23-2014, 03:51 PM   #5
Rewards Points: 4
Carpenter ants.
nanuk is offline   Reply With Quote
Old 07-23-2014, 04:28 PM   #6
Rewards Points: 8
Originally Posted by nanuk
Carpenter ants.
That was my first thought, but I haven't seen any ants.
I'll just call a pest control place and get it sorted out. The more I read, the more it looks like I should just let a pro take care of it.
Old powder post beetle damage to beam in basement - is it really a problem? nezwick Building & Construction 5 10-09-2012 09:12 PM
Post problems WillK Building & Construction 8 03-28-2011 06:16 PM
Tiling vertical post kellyharris15 Flooring 12 02-22-2011 03:28 PM
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 09:01 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
