Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 10-06-2012, 06:54 PM   #1
plant or insect on walls outside?
Since we've moved into our house we noticed these "things" (not sure what they are) stuck on the walls outside. See the attached images.
They stick pretty good to the walls and we have to remove each individual one by hand. However a few months later they've come back.
We live in south Florida. The Fort Lauderdale area.
Can anyone help identify what they are? Are they plant or are they an insect? And can anyone recommend something to keep them away or keep them from sticking to the exterior walls (stucco)?
please advise.
plant or insect on walls outside?-imag0014.jpg   plant or insect on walls outside?-imag0016.jpg   plant or insect on walls outside?-imag0017.jpg   plant or insect on walls outside?-imag0018.jpg   plant or insect on walls outside?-imag0019.jpg
etiennefamily is offline   Reply With Quote
Old 10-06-2012, 07:14 PM   #2
Google "bag worm images".
etiennefamily (10-07-2012)
Old 10-07-2012, 06:50 AM   #3
paper hanger and painter
chrisn's Avatar
Old Joe's got it!
http://www.google.com/search?sourcei...428&q=bagworms
Old 10-07-2012, 08:25 AM   #4
Call me nuts (and I am lol) but I just find insects amazing. What a neat way to hide there larvie right in plan site. Birds just think it's a pine cone and leave it alone.
If your seeing them out in the open like that I'd have to guess they has to be pine trees close to that area. They love hemlocks and Cedar trees. Once the larvie hatches there going to distroy the tree if not treated.
Old 10-07-2012, 04:13 PM   #5
Thank you. youve pointed me in the right direction.
seems what I have is "plaster bagworms" since Im in Florida.
again, thank you.
any advice on how to keep them away is most welcomed.
Old 10-07-2012, 05:45 PM   #6
chrisn's Avatar
You have to have an evergreen tree of some sort near by( at least you DID have one) You need to spray them when actively feeding, doing so now will have 0 effect, or you could just pick em off
Tags
stick, stucco, stuck, walls
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
No Floating walls where there should be! DIY Master Building & Construction 1 02-23-2011 06:06 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
