Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 09-11-2010, 11:19 AM   #1
pest problem
i need to know names of boric acid i can use for roaches
nella38 is offline   Reply With Quote
Old 09-11-2010, 06:22 PM   #2
pest control operator
pest problem
Look on the label of various products for the "active ingredients". That is where you will see if boric acid is the main ingredient. Di-sodium octaborate is another name for boric acid.
Boric acid requires that the roaches walk through it. Oftentimes they live in harborage that precludes boric acid powder application. I would urge you to consider any of the gel roach baits in hard to treat areas. They come in a syringe, not a bait station.
PAbugman is offline   Reply With Quote
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 09:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
