Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 01-13-2008, 10:38 PM   #1
Pest Cotrol-Termites
When you have a Pest Control Company spray for termites are they suppose to spray the rafters under the house or just around the foudation of the crawl space?
Dougit is offline   Reply With Quote
Old 12-24-2008, 12:50 PM   #2
Okay it depends where are you infected and how they say to treat the problem and help you get rid of termites. Most termite control companies don't use spray indoors but it all depends of the level of infestation that you are exposed too. An inspection from an exterminator ca solve that...
Kevin
KevinLorak is offline   Reply With Quote
Old 01-01-2009, 01:55 PM   #3
If the treatment is for subterranean they will only treat the supports
There is no reason to treat the joists because subs cannot get to the wood unless they construct mud tubes
if there is no direct ground contact they can not construct the tubes to get to the joist
Spent 25 years in Pest Control
Now I pull Raccoons out of peoples attics
ocoee is offline   Reply With Quote
Old 05-19-2009, 10:11 AM   #4
Xtreme DIY'r
Just a spammer - ignore them, they will be gone shortly
Old 05-19-2009, 10:48 AM   #5
Are they treating monthly for termites??Or other creepy crawlers? Tempo does a good job for me and is easy to spray but dont think it kills termites. Its the cats meow on spiders tho.
4just1don is offline   Reply With Quote
New Pest Control Forum! Nathan Pest Control 31 06-09-2011 07:52 PM
mold or pest? joeyboy General Discussion 7 01-12-2008 05:21 PM
Pest Control bugman Pest Control 1 11-18-2007 12:17 AM
Painting for Termites DaGoomba Pest Control 10 10-24-2007 12:00 AM
General Pest Control Willie5566 Pest Control 2 10-21-2007 05:25 PM
