Noise Inside The Wall! - Pest Control - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 03-01-2014, 11:38 AM   #16
Rewards Points: 690
Mice can get in a hole no bigger than a penny, So your mice may be entering nearly anywhere, possibly through a hose bib, or a hole drilled by the cable guy, or phone installer, I have seen holes made by woodpeckers that are big enough.
ED
de-nagorg is online now   Reply With Quote
Old 03-01-2014, 01:53 PM   #17
Chewbacka's Avatar
Rewards Points: 77
Yep, Walken is the man! He's from crazytown
Squirrel holes are going to be probably 3" or larger.
My mother's house had racoons living in the old unused chimney! It scared her Jamacian home health care woman big time!?
Your 'rodent' may be lost in your walls, time to start cutting huge holes randomly, especially at night! Just kidding.
Look at ductwork/exhaust pipes, soffit vents, anywhere there might be an access point for them to enter.
Chewbacka is offline   Reply With Quote
Old 04-06-2014, 01:13 PM   #18
Rewards Points: 109
A friend of mine had a similar situation, and it turned out to be raccoon. They sere getting in through a gap in the siding and squeezing up into the attic. He had to have them professionally trapped. You'll know if it's a raccoon...it sounds much bigger then a mouse or a rat.
CTgarret is offline   Reply With Quote
Old 04-23-2014, 10:02 AM   #19
Rewards Points: 44
that would drive me nuts, hope you get it sorted.
TheDoc46 is offline   Reply With Quote
Remortaring inside of foundation wall strategery Building & Construction 3 10-20-2011 01:25 AM
run spliced lamp cord inside a wall? denemante Electrical 20 12-17-2010 10:35 PM
Condensation inside wall on vapour barrier rovers1973 Building & Construction 1 05-14-2010 11:00 PM
Need advice on pouring slab inside existing wall. bmwbykrydr Building & Construction 2 04-05-2010 11:11 AM
Williams wall furnace whistling noise diyer_mi HVAC 11 10-23-2007 05:05 PM
