Noise Inside The Wall! - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 02-27-2014, 11:20 AM   #1
On the Road Less Traveled
The Jeep Driver's Avatar
Rewards Points: 91
Angry
Noise inside the wall!
For the past couple of months we've been hearing something, but we never could tell what or where it was. The noise always happened late, late night, and one of us would wake up, "Did you hear something?" Well, no doubt about it today! There is something inside the wall of our upstairs bedroom. Moving and/or chewing constantly. I have no ideas on how to get to it. I am probably just going to have to call someone over for this.
The Jeep Driver is offline   Reply With Quote
Old 02-27-2014, 12:36 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,444
Mice...........start looking for holes in your outside walls....the hole does not have to be big. Rats can fit through something not much bigger than a quarter.
The Following User Says Thank You to ddawg16 For This Useful Post:
The Jeep Driver (02-27-2014)
Old 02-27-2014, 12:43 PM   #3
Rewards Points: 91
How do you think I should start baiting them? I can't get to them. I went to the attic, no signs or sound there.
I have been all over the outside; I can't find any openings!
EDIT: I am going to start placing Decon bait stations in the attics and see if they get eaten.
Old 02-27-2014, 12:55 PM   #4
JOATMON
ddawg16's Avatar
I wouldn't do the bait stations....do spring traps and/or glue traps.
You don't want them eating the poison and then dying in the walls...better to catch them on the outside....
Look for mouse drippings (black rice).
jmon (02-27-2014)
Old 02-27-2014, 01:05 PM   #5
Rewards Points: 91
I looked for droppings in the attic, nothing. I have had mice in the detached garage, and have had luck with the glue traps and the Decon there. I am sure there were mice in the attic above the attached garage too, I suppose it's not a stretch to think they could end up in the wall, but I can't see how they'd get there... I mean it is the opposite side of the house. I can't explain it, you'd have to see the house layout.
EDIT: Great looking Jeep by the way.
Old 02-27-2014, 01:17 PM   #6
JOATMON
ddawg16's Avatar
Originally Posted by The Jeep Driver
I looked for droppings in the attic, nothing. I have had mice in the detached garage, and have had luck with the glue traps and the Decon there. I am sure there were mice in the attic above the attached garage too, I suppose it's not a stretch to think they could end up in the wall, but I can't see how they'd get there... I mean it is the opposite side of the house. I can't explain it, you'd have to see the house layout. EDIT: Great looking Jeep by the way.
Thanks.....takes a fellow jeeper to understand
Btw....those mice can sometimes fit in the holes in the top plate for your wiring
Old 02-27-2014, 01:51 PM   #7
Rewards Points: 91
I was thinking something larger than mice though. I didn't think mice could make that much noise. I'll start with treating for them and see if the noises go away.
Thanks again!
Old 02-27-2014, 05:20 PM   #8
Rewards Points: 1,626
Get a cat, or a snake.
de-nagorg is offline   Reply With Quote
Old 02-27-2014, 07:05 PM   #9
Rewards Points: 244
They can also drop down onto your roof if any trees are hanging over close enough. Once on the roof there are a dozen ways into a typical attic.
ChuckF. is online now   Reply With Quote
Old 02-27-2014, 08:47 PM   #10
Rewards Points: 54
Came home from a walk one night and saw 2 med size rats run across top of fence, then crawled up brick and under hardie trim!
Threw poison bait up and around all of the attic, in a few days the smell indicated our success. @ weeks later, smell gone as well as rodents.
Did not want to have to deal with traps to remove.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 02-27-2014, 09:29 PM   #11
Chewbacka's Avatar
Rewards Points: 77
It's likely mice, but could be a bat too. We hired a pest Co. and they found no mice, eventually found bats and refunded $.
I'd use glue traps, or peanut butter on snap traps. Don't worry about how they get in for now, focus on getting to them and eradication.
Either case is tricky, but you can win the battle, and must; mice can chew wiring and cause fire, potentially.
Chewbacka is offline   Reply With Quote
Old 02-28-2014, 08:40 AM   #12
Rewards Points: 91
My issue with traps in this case is the "attic" is such a pain to get in and out of. Little more than a hatch in the closet ceiling.
As long as it's just mice, (even rats, hopefully not though!), I can deal with it. There was so much noise I was sure there was something bigger.
Old 02-28-2014, 08:47 AM   #13
Do you have squirrels in your community?
Often they access attics looking for a warm nesting place.
ED
Old 02-28-2014, 11:24 AM   #14
Chewbacka's Avatar
Rewards Points: 77
ED
Ah, yes, squirrels, those pesky flying rodents! I've had them chew through the gable end of my CT house TWICE and build a humongus nest in the attic floor open joists. Sealed the gable end hole once only to have them come back and chew through again in the exact same place...What a nightmare. Had forgotten about squirrels, but this post reminds me of the havoc they wreak.
Hopefully you don't have them inside your house.
You could always seek out Christopher Walken and see what he could do for you! Movie: Mouse Hunt - a total riot!
Old 03-01-2014, 09:57 AM   #15
Rewards Points: 91
Yes I do! LOTS! And that was my first thought when I heard the noises the day I posted. I still can't imagine mice could make that much noise. I called an exterminator right after my first post; they said mice too. I see no entry points anywhere around the house. I would think a hole large enough for a squirrel to be using has to be fairly large, right? A visit to the attic shows nothing out of the ordinary.
I love that movie! The scene where he "samples" the mouse droppings... PRICELESS!
Remortaring inside of foundation wall strategery Building & Construction 3 10-20-2011 12:25 AM
run spliced lamp cord inside a wall? denemante Electrical 20 12-17-2010 09:35 PM
Condensation inside wall on vapour barrier rovers1973 Building & Construction 1 05-14-2010 10:00 PM
Need advice on pouring slab inside existing wall. bmwbykrydr Building & Construction 2 04-05-2010 10:11 AM
Williams wall furnace whistling noise diyer_mi HVAC 11 10-23-2007 04:05 PM
