Mouse Holes - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Like Tree2Likes
  • 2 Post By Bud9051
Old 10-29-2016, 07:50 AM   #1
Rewards Points: 4
Mouse Holes
Does anyone know if installing metal floor molding is an effective way to prevent mice from creating holes?
I recently moved into an apartment and with the cold weather, mice have become an issue. I searched for their entry points and have uncovered a few small holes in the drywall behind the kitchen appliances, which I've filled with steel wool and expanding foam. There wasn't any floor molding at all behind the appliances. If I install metal molding, would that prevent them from creating new entry points back there?
Molding is about 5 inches high. My concern is that they could just chew a new hole above where the metal molding ends.
JCMan is offline   Reply With Quote
Old 10-29-2016, 07:59 AM   #2
Rewards Points: 3,892
Re: Mouse Holes
Hi JC,
Actually, I like to leave a known entry point open and a couple of traps on the inside to greet them. Even if you successfully block all the holes you see they are still inside your walls doing their business and raising more trouble makers.
At one entry point above a basement window I set 3 traps and over a few weeks I caught probably a dozen mice. Then the count went to zero and I closed off the hole. But that way I knew there were no more critters searching the exterior of my home to find another point.
You could create a wire cage to enclose the traps and place it where they can get to the traps but not further inside.
Just my thoughts.
Bud
Bud9051 is offline   Reply With Quote
Old 10-29-2016, 08:04 AM   #3
Rewards Points: 13,712
Re: Mouse Holes
Talked to the landlord yet about this issue?
Far better to kill the mice and seal up the holes on the outside where there getting in.
Old 10-29-2016, 08:19 PM   #4
Rewards Points: 296
Re: Mouse Holes
I agree, better to kill them off. If you must put on molding, you can put wire hardware cloth, about 1/4" grid, under the wood molding before you put it on. Home Depot.
ChuckF. is offline   Reply With Quote
Old 10-30-2016, 07:22 AM   #5
Rewards Points: 4
Re: Mouse Holes
Agreed that best solution would be to seal the entry points outside the building, but it's not a house, it's an apartment building in a city...so rodents are somewhat of an expectation. I just want to keep them out of my unit.
Anyone have experience with metal molding? I assume a mouse can't chew through metal. But would they just chew a hole above the molding instead?
As i mentioned, the known entry points are behind kitchen appliances, so they are impossible for me to monitor. I'd like to create a solution once and for all back there where i'll know that they can't come through.
Old 01-16-2017, 06:18 AM   #6
Rewards Points: 76
Re: Mouse Holes
i will give you some home-made solutions
1) put some "Red Chili powder" near mouse hole.
2) put some onion slice near mouse hole.
i hope it is helpful for you...
viveksuthar is offline   Reply With Quote
Old 01-24-2017, 07:26 AM   #7
Rewards Points: 6
Re: Mouse Holes
I am petrified of mice and terrified of the diseases they can spread. Wouldn’t depend on moldings to cover the holes. Had a similar problem a couple of years back and contacted .............. because they said they used humane pest control techniques. You’ve got to do more than covering their entry points and you don’t need to get rid of the problem yourself when there’s help at hand.
Stephaniecraft is offline   Reply With Quote
Old 02-09-2017, 04:38 PM   #8
miceblocker's Avatar
Rewards Points: 6
Re: Mouse Holes
Based on my experience, mice cannot chew through steel that is 20 gauge or thicker.
miceblocker is offline   Reply With Quote
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 10:32 PM
Patching vinyl siding to "repair" small holes tomseeley Building & Construction 3 06-05-2011 09:12 AM
Holes in yard under tree - what is it? Leah Frances Pest Control 13 05-11-2011 07:22 PM
The Better Mouse Trap? forresth Off Topic 26 10-09-2010 11:07 PM
Drilling Multiple Holes in Studs rjschwar Building & Construction 6 01-27-2010 01:05 PM
