Moth Flies, Or Drain Flies - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 04-05-2011, 03:17 PM   #1
Moth flies, or drain flies
I am beside myself with this problem, they are either drain or moth flies, but they are coming into my home from all over, through the screens, windows, dryer vents, window air conditioners...this has been going on for 3 years now, and i am on my last nerve. they are litterally running me crazy, i cry all the time, because they won't go away. me and my husband took up our mulch, caulked everything, but no matter what we do they don't stop. this is in the front and back of our home. what can we do!!!!!
moranjean is offline   Reply With Quote
Old 04-07-2011, 05:13 PM   #2
pest control operator
You must get a positive identification as to specifically what they are. Catch some and take them to a county extension office, agricultural office, etc. Here in Pa. it would be an extension of Penn State.
If they have already been identified as moth or drain flies, also know as sewer flies (psychoda), then you have a drain or sewage problem. These flies indicate a broken pipe, slow or clogged drains. Could be broken right outside the house, since you say the come in from outside, which is unusual.
Search "psychoda" on internet. If this is what you have, then forget about caulking, mulch, etc. You may have a serious septic/sewage problem. Could be right outside foundation wall, or under a slab. Lets us know what you find out, but get a positive ID first, then we have a direction to go. What part of the country are you in?
PAbugman is offline   Reply With Quote
I have drain flies ivernon Plumbing 2 11-21-2010 06:24 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Drain flies under house fly slayer Plumbing 1 06-03-2009 11:35 AM
Drain Flies - Help! mcstan Pest Control 4 05-10-2009 03:31 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
