Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 09-29-2009, 12:01 AM   #1
Default mosquito mister- do they work?
Hi all,
After 10 bites in < 10 minutes, i am getting fed up with mosquito's in my backyard (Houston, TX). I've tried the mosquito magnet which killed alot of mosquitos, but we were still eaten alive. I've cut down all my azalea bushes (they weren't doing that well anyway) and i've been spraying the yard all season and we're still being eaten up.
Has anyone had experience with mosquito misters that use pyrethrum? I've seen some self-installed systems and wanted to know if anyone's tried them. we're getting desperate. my family loves to work/play outdoors, but we're afraid to go outside half the year.
Thanks!
jkh772 is offline   Reply With Quote
Old 09-29-2009, 06:43 PM   #2
DIY Hack
Mr Chips's Avatar
Default smells great too
never tried a mister, but i used this stuff all summer and was very impressed.
it's safe, evironmentally friendly, and worked great too
There is plenty of room for all God's creatures...
Right next to the mashed potatoes.
Mr Chips is offline   Reply With Quote
Old 09-29-2009, 07:52 PM   #3
paper hanger, painter
chrisn's Avatar
Send a message via Yahoo to chrisn
How about a couple of bat houses?
http://www.batroost.com/bathousesand...FeEN5QodXCP68Q
Old 09-29-2009, 08:07 PM   #4
Extreme DIY Homeowner
Scuba_Dave's Avatar
Mosquito maganet must be setup & running in advance to stop the breeding cycle
They recommend 3-6 weeks, after temps are in the 50's
A friend had neighbors on all sides that had them
A long day/night BBQ/pool party there maybe a few mosquitos
Wind will blow them around, so if you have a strong wind/storm new skeeters will be blown in
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Old 09-29-2009, 11:44 PM   #5
thanks for the responses.
we tried the mosquito magnet for 2 seasons. Iit killed alot of mosquitos. the basket was full every time i emptied it, but we were still being bitten alot even after repositioning it.
Mr. Chips, how did you distribute the product? with a spray attachment to a garden hose?
I would like to hear if anyone's heard any news- good or bad about the misters.
Thanks!
Old 09-30-2009, 08:44 AM   #6
DIY Hack
Mr Chips's Avatar
I wanted to do the sprayer on the hose, but they specifically recommend not to. I just pour 6-8 ozs into a 2 gallon pump sprayer with a wide angle tip, fill with water and walk around the yard spraying on the grass. I usually did it around 9 or 10 p.m. Your yard will smell like a sub shop for an hour or two, but to me that was an added bonus!!
I got my neighbors hooked on it too, so I am sure that helped to keep bites low. Four of us went in together on a case of gallons, so we got a discount and free shipping. total cost was about $75 a gallon, and I don't think any of us ended up using more than about half a gallon. we were all very pleased with the results.
Old 10-16-2009, 12:32 PM   #7
fastfacts's Avatar
Some good advice here, I am having a serious mosquito problem lately but its more than they seem to get into my bedroom and there hard to catch during the day there good hiders, I get bit a lot any advice for getting them out of the room?
fastfacts is offline   Reply With Quote
More On This Topic
This hose end sprayer has a few features and adjustments that you can do to make sure that your application is correct. One of the things it has is on the very top it has a list of numbers it goes 1 2 3 4 all the way up to 7 and then it jumps to 10. In... Read More »
One of the other things that you want to do- when the tree is dormant, you want to spray it with dormant oil. Here is some dormant oil, and you put it in a hose sprayer. It will tell you how to use per gallon on the bottle and then your hose sprayer will... Read More »
We loaded our hose in self metering sprayer with the pesticide we're going to be using today which is water actually. But any way for demonstration purposes we're going to demonstrate how this thing will put the chemicals into the water and the different... Read More »
Beer is normally produced from barley and flavored with hops. The brewing process for this alcoholic beverage also includes fermentation. Now beer can be put to good use in garden maintenance as an alternative to harsh chemicals. So both you and your... Read More »
In this segment we're going to talk about different kinds of herbicide that are available for you lawn for weed control. This product is a post emerge, that means that the weeds will be up, selective broad leaf herbicide. That selective broad leaf... Read More »
Does your job require a permit? housedocs General Discussion 179 Today 08:42 AM
Is it right that an owner must be licensed to perform work joey b Electrical 45 12-16-2008 12:16 PM
duct work framing kama Carpentry 4 11-15-2008 02:40 PM
Properly Sealing HVAC Duct Work craymer45 HVAC 5 11-06-2008 10:47 PM
Can a homeowner perform electrical work in MA? dpd512 Electrical 23 10-25-2008 11:17 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
