Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 01-24-2009, 12:57 PM   #1
Default Moles
Any advice on how to get rid of moles? I have tried everything except dynomite! They are really tearing my yard up big time. My yard is almost 5 acres and you could hold a baja race in it. Tahanks
mbhb8803 is offline   Reply With Quote
Old 01-24-2009, 05:16 PM   #2
Lot's of water, the resussitate them in a barrel with lead through the head .22....... They're nasty when they're wet!
Chemist1961 is offline   Reply With Quote
Old 01-26-2009, 09:03 AM   #3
Try putting small pieces of chewing gum into the holes.
47_47 is offline   Reply With Quote
Old 01-28-2009, 07:10 PM   #4
Pavement
Old 10-29-2009, 01:41 PM   #5
ArmchairDIY's Avatar
Originally Posted by mbhb8803 View Post
Any advice on how to get rid of moles?.....
Try placing a small piece of duct tape over it for a few days then......oh wait, never mind thats for warts not moles.....lol
ArmchairDIY is offline   Reply With Quote
Old 10-30-2009, 09:33 AM   #6
Long-Time DIYer
Mike Swearingen's Avatar
You may laugh and you may scoff, but I have been using this simple and safe (for pets) method for years, and it WORKS!
Roll two peeled pieces of Juicy Fruit gum together, poke a hole in the run and push the gum down to the bottom of the run. Cover the hole back up. Do this in all runs, sometimes in 2 or 3 places.
The moles eat the gum, but cannot digest it and it kills them.
I recently wiped out about six of them that invaded from an adjoining vacant lot doing this.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 10-31-2009, 06:27 PM   #7
I've had good success trapping them with a traditional harpoon mole trap. See description at http://www.themoleman.com/control.htm. The key to success is finding an active repeat run, not a temporary tunnel.
Itsdanf is offline   Reply With Quote
Old 11-01-2009, 01:12 AM   #8
At school, we would flood the holes with water. We then stood by the hole and kicked the rodents in the head when they popped up.
Grandma quite feeding the outside cats, the cats then controlled the moles.
A friend had gophers invade the lower field near the canal. He took his backhoe and squashed the gopher holes down.
We used to sell gopher bombs. People dropped them in the hole and lite the bombs. The poison gas worked very well. The bombs are probably not available now.
A tractor or truck (preferably one that used a mechanical choke) and a flex hose. the hose was put in the hole, and the vehicle started. The rodents became fertilizer.
fireguy is offline   Reply With Quote
Old 11-01-2009, 04:40 AM   #9
paper hanger, painter
chrisn's Avatar
Send a message via Yahoo to chrisn
These might work
Old 11-01-2009, 08:54 AM   #10
With the right frame of mind, chasing moles is a form of entertainment. At one time I use to go after them, setting traps, putting gum in runs, moth balls, fill runs up with the garden hose, pat down the lawn, sit back and watch when they come back through and push the dirt up so you can see it move, then dig quick with a shovel. As for the cats, I had one cat that could dig up the yard worse then the dog. Now adays, I just wait until the neighbors yard has more grubs them mine and the moles move on to next door.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
More On This Topic
Creating a planting bed takes a lot of know-how. If you don't prepare your soil properly, you invite a host of problems. Once you have your bed, you should protect it from such common pests as rabbits, moles, chipmunks, even your dogs and cats. The only... Read More »
Hi. This is Yolanda Vanveen on behalf of Expert Village. In this series, we've learned all about how to start a compost heap. But, once you've got your garden started and your compost heap started, what do you do about the deer? What do you do about the... Read More »
Many people believe that cat litter has only one purpose, and therefore don't realize all of the wonderful ways that it can be used in the garden. Cat litter is most often made from natural clay that comes straight from the Earth, making it safe and... Read More »
Did you move into a house and find stray cats on the back porch, in the garage, basement, outbuildings or crawl spaces? If you don’t want any feral felines hanging around, here are some steps to convince them to move on. Read More »
On behalf of Expert Village, my name is Sally Head and today I am going to talk to you about how to nurture your preschoolers imagination. Providing props; take everyday materials such as a towel and it becomes a cape or you can take chairs and tables... Read More »
Mole Issues mattflytx Pest Control 24 06-07-2009 12:37 AM
Moles unde pool liner...causing "craters" abacuslearns Landscaping & Lawn Care 1 10-27-2007 09:37 AM
Chipmunks or moles? Proulx06 Landscaping & Lawn Care 1 07-09-2007 02:17 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
