-   Pest Control (http://www.diychatroom.com/f51/)
-   -   Moles (http://www.diychatroom.com/f51/moles-36701/)
mbhb8803 01-24-2009 11:57 AM
Moles
Any advice on how to get rid of moles? I have tried everything except dynomite!:) They are really tearing my yard up big time. My yard is almost 5 acres and you could hold a baja race in it. Tahanks
Chemist1961 01-24-2009 04:16 PM
Lot's of water, the resussitate them in a barrel with lead through the head .22....... They're nasty when they're wet!
47_47 01-26-2009 08:03 AM
Try putting small pieces of chewing gum into the holes.
Mike Swearingen 10-30-2009 08:33 AM
You may laugh and you may scoff, but I have been using this simple and safe (for pets) method for years, and it WORKS!
Roll two peeled pieces of Juicy Fruit gum together, poke a hole in the run and push the gum down to the bottom of the run. Cover the hole back up. Do this in all runs, sometimes in 2 or 3 places.
The moles eat the gum, but cannot digest it and it kills them.
I recently wiped out about six of them that invaded from an adjoining vacant lot doing this.
Good Luck!
Mike
Itsdanf 10-31-2009 05:27 PM
I've had good success trapping them with a traditional harpoon mole trap. See description at http://www.themoleman.com/control.htm. The key to success is finding an active repeat run, not a temporary tunnel.
fireguy 11-01-2009 01:12 AM
At school, we would flood the holes with water. We then stood by the hole and kicked the rodents in the head when they popped up.
Grandma quite feeding the outside cats, the cats then controlled the moles.
A friend had gophers invade the lower field near the canal. He took his backhoe and squashed the gopher holes down.
We used to sell gopher bombs. People dropped them in the hole and lite the bombs. The poison gas worked very well. The bombs are probably not available now.
A tractor or truck (preferably one that used a mechanical choke) and a flex hose. the hose was put in the hole, and the vehicle started. The rodents became fertilizer.
DUDE! 11-01-2009 07:54 AM
With the right frame of mind, chasing moles is a form of entertainment. At one time I use to go after them, setting traps, putting gum in runs, moth balls, fill runs up with the garden hose, pat down the lawn, sit back and watch when they come back through and push the dirt up so you can see it move, then dig quick with a shovel. As for the cats, I had one cat that could dig up the yard worse then the dog. Now adays, I just wait until the neighbors yard has more grubs them mine and the moles move on to next door.
cody21 04-14-2010 11:00 AM
Fish Emulsion - I've sprayed this over the entire yard to really saturate it - and into the 'runs' they create. Don't dilute it too much. Then water the yard like every other day to help leach the stuff down into the earth. Something about the horrible fishy smell of it seems to work. Good luck.
Wingingit 04-17-2010 01:52 AM
Mole Hunting
Home Depot/Lowes sell a unit that is 3 sided with a top, black plastic or wood. Sides are about 6inches, 3 inches tall, 4 inches wide.
Metal frame trap wire at open front end is set, box is placed in the ground at the fresh mole opening, facing the direction last traveled. Mole hits the trap wire, and he's road kill. Pull box out, remove dead mole and place him back in the hole...or show the wife and kids..whatever floats your boat.:laughing:
gma2rjc 04-17-2010 12:45 PM
The moles are gone now, but how do I get rid of the 50 or so cats in my yard looking for fish?
Just kidding. I'm going to try the fish emulsion. I used the Wrigley's gum last year and it worked great for a while. But they're really tearing up my yard this year. Did you use a tank sprayer to spread the diluted fish emulsion?
Barb
cody21 04-17-2010 01:00 PM
Barb
ha ha... Yes, a sprayer that connects to a garden hose. Just keep an eye on it so it doesn't dilute it too much. I poured it full-strength into open holes that I saw. good luck ... I'd like to hear back from you if it worked for you.
gma2rjc 04-17-2010 05:15 PM
Thanks! I'll try that and I will let you know how it works.
I've been working out in the yard today and I found 3 holes in the ground (each about 2" across). They were just a couple inches away from the foundation of the house and right near the garden hose, so I put the hose down in one of the holes and let it run for a minute thinking it would flush something out. It didn't and I didn't want to run the water near the foundation very long.
I think I've seen at least 10 or 12 holes like that in the yard today. Hopefully this will soon be a thing of the past.
Barb
cody21 05-01-2010 10:22 AM
Barb
There is another approach - one that I'm currently trying since my fish emulsion thing didn't seem to work this time. (new property we just bought - plagued iwth a gopher(s). There is a product I just found - it is a Sulpher thing that looks like a large firecracker and has a fuse. You light this thing and stick it down into a hole and then cover up the hole. The odea is that the Suplher smoke snakes out through the tunnels underground. I just inserted 2 of them yesterday so don't yet know the results. If this works, I'll report back ... Good luck !
piste 05-03-2010 09:07 AM
I'm waging the war as well. Right now trying a combo of the Sweeney's sonic spikes and some granular repellent that I can't recall the name of. We'll see how it goes.
gma2rjc 05-03-2010 09:45 AM
I'm anxious to hear if the smoke works. Thanks. Good luck with it.
I did have good luck with the Juicy Fruit gum last year, but later in the season the moles seemed to come back with a vengeance.
