Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 02-02-2011, 01:22 PM   #1
Mice and winter
So I found the hole they are getting in. Question now is do I seal it up during the winter knowing they are already in the walls/attic? Or do I leave thier path open so they can get out especially when it gets warmer. Then seal up and trap in late spring.
Thoughts?
ferris13 is offline   Reply With Quote
Old 02-02-2011, 01:38 PM   #2
Retired
Edgar214's Avatar
Mice and winter
I put D-Con in my attic every winter. If they die up there ain't much left to stink.
Mike
Edgar214 is offline   Reply With Quote
Old 02-02-2011, 05:34 PM   #3
pest control operator
Mice and winter
I keep rodent bait and snap traps set year round in our house. I've found entrys and sealed, but now and then it happens. My philosophy is that I would rather have dead mice than live mice.
I like to use rodent bait blocks, as opposed to pellets or meal that may be stashed, but that's just me. Use whatever has worked for you in the past. Keep it away from dogs. After baiting and setting traps, seal the hole.
PAbugman is offline   Reply With Quote
Old 02-03-2011, 09:25 AM   #4
Mice and winter
Thoughts?
Set traps and/or poison, or whatever steps you choose to take for those that are already in, but seal the path now, and don't assume that to be the only way in, so while you are at it, look for other areas that may need attention. Leaving it open for them to leave at their convenience only provides an opportunity for their friends to join them.
Old 02-03-2011, 11:20 AM   #5
Mice and winter
Thanks for the advice. Now to figured out a way to seal it up in these temperatures. The hole is under my dryer vent where it exits the brick and rather large.
Just pack with steel wool and wait till spring to morter?
Old 02-03-2011, 11:32 AM   #6
Experienced
Jackofall1's Avatar
Mice and winter
Steel wool, morter in the spring works
Mark
Old 02-03-2011, 12:01 PM   #7
Mice and winter
Make sure the mice cannot get into the dryer vent itself as they will then chew thru the vent hose if it is plastic. Set some snap traps right outside the exterior vent, under shrubbery if you have it, in window wells, etc. Look for burrowing, tunneling while you are out there. They are conditioned to come in that hole, when it is closed they will look for the next closest thing which is the vent itself. I've seen this happen.
Would be a good idea to inspect the vent hose well, as they may already have nesting material inside it.
Deer Mice, Where do you come from? PTP WX Pest Control 5 11-02-2010 01:12 PM
Preventing mice problem f8lyer8s Pest Control 21 02-19-2010 08:04 PM
Mice and Rats ThisOldShack Pest Control 7 08-20-2008 03:50 AM
More on Mices Fix-It Chick Pest Control 33 04-13-2008 10:15 PM
