Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 12-06-2012, 09:26 PM   #1
Mice coming through gas fireplace vent
We have a gas fireplace (the kind that turns on with a light switch) and a metal vent out the back of the house. We have had mice coming through the vent (or around the vent). We are unsure how to block access points for the mice that are also not flammable. My pest control guy said steel wool which I knew could catch on fire. Any suggestions would be helpful. Thanks!
meapmartin is offline   Reply With Quote
Old 12-06-2012, 09:33 PM   #2
Use galvinized hardware cloth. It's a 1/4" mesh wire screening.
meapmartin (12-06-2012)
Old 12-07-2012, 10:43 AM   #3
Hardware cloth will work over the vent out, but if you believe they are coming also (or rather) from the hole the vent makes in the outside surface of the house, you can use a copper sock to fill that hole around the vent pipe. For a small job like a vent, the copper sock can just be one of those dish cleaner copper pads (they unroll to about 3' long). The copper will not rust.
I dont think that steel wool will burn at the vent exit, but it will rust. If the steel wool can burn, why wont the house catch fire with or without the steel wool?
Why are they coming in the vent? Is it close to the ground? Is there landscape plants near that vent? Is the outside siding, or brick? Does the vent have a flap?
gobug is offline   Reply With Quote
Tags
gas fireplace, mice, vent
Damn Mice Keep Coming Back! dougp23 Pest Control 8 08-03-2012 06:09 PM
gas fireplace with same vent as furnace & water heater? Van3 HVAC 0 01-30-2011 05:21 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
Help! no air coming from master bedroom vent!!! thomasmona HVAC 3 06-02-2007 10:56 PM
